Fan stopped working, truck overheated. - Hemi Truck Club
Old 07-21-2014, 07:41 PM   #1
rowdog_14's Avatar
Well fan fuse had melted. I put my gauges back in went and drove my truck. Gave it hell the whole time. Well I pulled into the driveway and my temp was almost at the red!!!!!! I did not even notice until my check gauge light came on. I hope I did not do any major damage . I I turned te engine off spliced the fan wires together and the started the truck back up. That was it could cool without the hot fluid just sitting in the engine. It started to cool back off but xt he damage is probably already done
Current upgrades
- Jet 180 - Mopar Gauges- Class IV hitch - Borla Cat-Back - 4ga Dynamic Grounding - 10ga TB grounding - Sonnax trans line pressure - BBK Shorties#4009 - TheFastMan 85mm Throttle Body - SCT HemiFever Custom Tune - Magnaflow y-pipe #10748 - Doug's cutout #H1131 - K&N Intake 57-1533 - Comp 268 Cam -6.1 springs, pushrods- Summit UD Pulley
Upgrades to come and I am done:
1.Edge Torque Converter (2400-2600) 2. Race Ready Electric cutout 3. Detroit True Trac 4. Motive 4.10 gears 5. McGaughys shackles
rowdog_14 is offline   Reply With Quote
Old 07-21-2014, 07:43 PM   #2
Unhappy
Old 07-21-2014, 08:09 PM   #3
It's likely ok. Let it cool down then start it back up and idle it for a little while. I have seen way worse and no issues. You should be fine.
Old 07-22-2014, 08:14 AM   #4
rowdog_14's Avatar
That is good to hear
Current upgrades
Old 07-22-2014, 10:17 AM   #5
David
ATXHEMI's Avatar
Mine did the same. I soaked my radiator with the water hose to cool her back down. Been about a year. No issues at all.
Old 07-22-2014, 02:22 PM   #6
I have an alert set on my AeroForce gauge to come on at 203 degree's. I seldom see it but I like having it as a backup.
Old 07-22-2014, 04:13 PM   #7
Matt
MANual_puller's Avatar
My 2006 has an audible alert when the check gauges light comes on. It dings at me. I take it yours doesn't work or it's a newer feature?? I think it's the same chime used for headlights/seatbelt etc....If it's disabled to not be annoying it won't tell you there's a problem either. Might be worth looking into.
Old 07-22-2014, 07:31 PM   #8
My 05 has it and it's pretty loud the random ding running wot when it gets hot
Lol. Mine went off when I blew the heads and didn't care lol.
Old 07-22-2014, 08:02 PM   #9
Matt
That's what I'm saying, it is pretty loud, the chime might be disabled or not working to not notice the check gauges light coming on.
Old 07-23-2014, 07:07 AM   #10
rowdog_14's Avatar
Mine works. That is when I noticed it. When the 'check gauge light' came on the standard 'ding' alert came with it.
Started it up last night when I got home after work and all seemed fine. Idled nice, and rev up nice too with no issues. Only time will tell now but I feel good after starting it up yesterday.
Here are pictures of the damaged wires and the new fuse holder I got.
Current upgrades
