DTC code plague - Hemi Truck Club
Old 01-13-2015, 07:41 PM   #1
Matt
MANual_puller's Avatar
DTC code plague
Had 9 DTC codes logged when I checked today I had the ABS and brake lights on.
Providing the codes and what I could find about them in case I'm wrong.
5 of them I'm not too worried about.
1) P0128-[cooling sys error] I have a 180* thermostat that caused that one
2) B1421-[CD read error] pretty self explanatory
3) B1648-[Rear right turn conrol circuit high] replaced the burnt bulb 2 weeks ago
4) B2305-[Wiper park switch input circuit high] Hit the wipers on accident while they were froze down, they still work
5) B236F-[window washer motor]-washer fluid froze at -23* the other morning
Last 4 bother me some.....
6) C1011-[LF wheel speed sensor signal erratic performance] I have no idea what erratic performance is supposed to mean.
7) C1014-[LF wheel speed comparative performance] Compared to what? Right side? Rear?
8) C1036-[Rear wheel speed sensor] ***This one was hard to find and not sure if that's right because it didn't say what was wrong with the sensor......speedo still works??
9) U1417-[Implausible left wheel distance signal received] Kind of makes sense with the other two LF codes but I couldn't find where it specified front or rear????
So I cleared all the codes, drove around the block and so far the only one to return is C1014. The day that my dash lights lit up I had just hauled 3 deer out of a pasture and drove 15 miles to the next hunting site. I was decelerating on the gravel road to turn into the driveway when the truck dinged at me and lit up. I'm looking for clarification on what those last 4 codes can mean. Thanks in advance!!
Oh, btw my truck is a 2006 2500
Old 01-13-2015, 08:42 PM   #2
Ok you really need a scanner to see what the comp is seeing or you can measure the resistance of the sensor and compare to right front. Worst case swap left front and right front hubs and see if right side throws code then. If you had a scanner simply drive down street and sensors will be same or diff. Code is sensor issue. Possibly bad hub also
Old 01-13-2015, 08:49 PM   #3
Matt
I had to do the right side hub at 60k. I was afraid of that. I've been trying to save up money for a set of spyntech lockout front hubs. They're stronger and have serviceable bearings. This is going to be a setback to that idea....... Guess I'll be pulling the wheel off tomorrow night for a closer inspection, thanks Keith!
Old 01-13-2015, 10:04 PM   #4
Old 01-14-2015, 05:25 PM   #5
Matt
LF wheel bearing is rough. Couldn't get any wiggle out of it but it doesn't sound/feel healthy when I turn it by hand. New parts on the way, hopefully my stupid dash lights go away with the bad bearing
Old 01-14-2015, 06:17 PM   #6
Board of Directors-Bill
arocketman's Avatar
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 01-14-2015, 06:44 PM   #7
Old 01-14-2015, 09:34 PM   #8
Gold-Member
kcd1369's Avatar
Old 01-15-2015, 09:31 AM   #9
Matt
Old 01-15-2015, 06:37 PM   #10
Matt
Well, this isn't going to be as easy as I thought. I think we're going to have to use some extra motivation in the form of a blue wrench and 3/4 drive impact I broke my 1/2 in drive breaker bar.
