BV Heads? - Hemi Truck Club
Old 07-09-2014, 06:16 PM   #1
BV Heads?
Who has the best/affordable BV heads for a 5.7? I can get a pair of heads done at my local performance shop for around $1500. What's a good price to pay for what is generally described as Stage II heads? I have a Track PPP cam I want to install, but really need to do heads first.
Thanks,
Old 07-09-2014, 10:01 PM   #2
I would say around 2200+ easy for big valve heads and porting from a site likely a core charge too
Old 07-10-2014, 07:31 AM   #3
Appreciate the input. The price from my local shop is for reworking my heads. The prices from say Inertia or PPP would have a core charge added to it. I'm leaning toward PPP as it's their cam I want to use and should be a good package. But the job of street performance heads is to be reliable and still flow. Racing heads are all about performance and I want a balance of performance and some durability. I just don't know who's best for what I'm looking for..
Thanks,
Old 07-10-2014, 10:34 AM   #4
I don't think you'll notice a diff much either way street wise it's the dyno that would Deff show a diff
Old 07-10-2014, 10:54 AM   #5
The little I know about heads is mostly around the valve angles. The race valve usually has a thinner seating area which flows better but doesn't transfer heat as well as a wider seat area. Narrow seats wear faster than standard seats. I don't intend on running really high spring pressures with an advertised lift of .575. I just don't know which supplier has defined the compromises needed to have high flow and durability from the same head. After all it is a bit of black art. Stu from Inertia did get back to me this morning which is encouraging.
Old 07-10-2014, 08:03 PM   #6
You could just port the heads and put stock sized Manley
Pro Flow valves in. Have the heads milled a little.
Old 07-10-2014, 08:12 PM   #7
I agree. I also have heard the 6.1 intake valve with stock exhaust makes a good 5.7 combo. Maybe with PPP valve springs along with a little porting and a .030 mill would get it done. My local motor shop is doing more hemi's now so I'll probably stop and talk with the owner.
Old 07-10-2014, 08:24 PM   #8
The intake side is good it's the exhaust side that needs the work. I got so excited I had mine back that I didn't port them before installing them. A simple larger valve setup with a decent amount of exhaust porting will be a nice diff.
Old 07-10-2014, 08:32 PM   #9
Good to hear, I really need to talk with my shop as that would by my guess the best bang for the dollar. These guys build very serious engines.
