back 2 bushings on lower control arms? - Hemi Truck Club
Old 02-04-2018, 09:12 AM   #1
bee # 549's Avatar
how hard is it 2 change only the back 2 bushings on lower control arm ? this is on my 2004 ram rumble bee rwd 2x4 hemi
thanks for any advice.
srt-10 bumper cover.
srt-10 floor console.
6.1 ignition conversion.
BOSS 338B 22X9.50 RIMS
black headliner.
black headlights soon
bee # 549 is offline   Reply With Quote
Old 02-04-2018, 04:34 PM   #2
A little of a pain you have to drop the lower enough to release the spring from the perch to allow arm removal after that a press and your golden.
Old 02-05-2018, 12:07 AM   #3
Truck of the year 2014
Belgiquebasterd's Avatar
Didn't have a press when I removed mine couple years back, was quite the struggle to get the old bushings out, the rubber had vulcanized to the metal of the spring eye, ended up using a lot of heat, drilling through the rubber multiple times then had to use a scraper and a whire wheel to get the leftover rubber of the metal.
Good luck!
Old 02-05-2018, 06:52 AM   #4
bee # 549's Avatar
lower control arms
I think I will just get new control arms from rock auto for 70 dollars each save my self some stress. from what I have read they come out real easy ?
black headliner.
Old 02-07-2018, 09:00 PM   #5
Yes and no won’t know what’s easy till you get in there. I do this daily so yes it’s easy but if you don’t do this daily it can be a challenge.
Now that I look at your name you have BEE and that’s a torsion front end. These are much easier/safer IMO to work on you should not have an issue but will need an alignment when done for sure
