Any mods from 04-07 that can be applied to an 03? - Hemi Truck Club
Old 07-31-2014, 03:20 PM   #1
Tom
BadassBlues's Avatar
I am just curious if there are any modifications or upgrades to the 04 through 07's that can be applied to the 03?
I had considered buying a new intake manifold to put on my new remanufactured engine and discovered that they are now equipped with the EGR, even for the 03's. You have to buy the EGR separately.
BadassBlues is offline   Reply With Quote
Old 07-31-2014, 03:59 PM   #2
Not sure what you are asking. But I use 06 dual coils on my 03. As for the actual intake manifold, I believe you should stick with the 03 manifold. CAI's are pretty universal to a point. Trans mods, converters rear ends are the same. If you understand the differences in the exhaust design you can even switch that around.
Old 07-31-2014, 05:20 PM   #3
Tom
I suppose I could have worded it better. Did they make any significant improvements to the later models that could be incorporated into the 03?
The intake manifold changed, from what the dealership told me. The original 03's didn't have EGR and now all of the manifolds for 03's include the EGR port and you have to buy the EGR valve itself separately. That was a major reason I didn't go ahead and buy it.
My other one cleaned up nicely, so no big deal on that. Although I have to say, I was shocked that it was plastic. It's been a long time since I had my hands that far in to an engine and the last time I installed an intake manifold it was an edelbrock and a 4 barrel Holley carburetor on my 1976 Trans Am.
Like I said.. mechanically inclined and technically ignorant. I have a lot to learn about these newer vehicles.
I do want to add that I sincerely appreciate the help!
Old 07-31-2014, 05:38 PM   #4
It is indeed a continuing learning process which is part of the fun of it. Actually the manifold being composite is a good thing as it resist heat soak. 06 exhaust valve springs are pretty much the standard upgrade with a cam or not. There have been a problem with some 03/04's having the originals break. I don't like having the waste spark wires and use the 06 dual coils. Personal choice..
Old 07-31-2014, 06:14 PM   #5
They are wrong. '03 trucks have no means to control the EGR solenoid nor is the passenger side exhaust manifold ported for EGR. I don't believe any 2500 Hemi truck had EGR on it, maybe ask for a manifold for those.
Sold: 2003 Dodge Ram 1500
Old 07-31-2014, 07:45 PM   #6
Tom
You are likely correct. The dealership parts dept. here is less than stellar. Also, searching for this part online is highly ambiguous as there are few places that even stock it and descriptions are vague.
Old 07-31-2014, 08:26 PM   #7
If your factory manifold is working why change it the 2003-2008 use the same manifold onl diff is the egr hole is drilled on 04-08 1500 models. They all make the same hp and torque. Vale springs I suggest upgrading especially if you add a cam.
Old 07-31-2014, 09:39 PM   #8
Tom
I had two major blow outs. My power steering blew fluid all over my engine. Then when my engine blew, it got oil everywhere. It was a real mess. As I was cleaning the truck and parts when the engine was out, I decided to replace a few as this was the ideal time.
The manifold was caked in sludge. Power steering fluid makes a sticky glue like residue. The design of these manifolds is really annoying from a cleanliness perspective. The have ridges and pockets covering the entire top. I figured it would be easier to just buy a new one. I opted to clean the original however and it took 4 hours with a small brush and solvent. I was advised to leave the carbon alone ( which was excruciatingly hard to do because I get OCD while in project mode) so I just cleaned the top and the wiring harness. It ended up looking great, so I'm happy.
Old 08-03-2014, 08:47 AM   #9
Why not clean the carbon out?
03TR is offline   Reply With Quote
Old 08-03-2014, 09:04 AM   #10
Truck of the year 2014
Belgiquebasterd's Avatar
I would say that the biggest upgrade was the swap from seperate PCM/TCM modules to to single module, wich gives you trans tuning, idle conrol, rpm limiter control,...
Greg, what's the advantage of the dual coil system compared to shorty wire system?
