air conditioning problems 2005 ram 2500 - Hemi Truck Club
Like Tree1Likes
  • 1 Post By Lil Red 78
Old 05-07-2018, 09:08 PM   #1
I have a 2005 RAM 2500 SLT with 86k miles. hemi slt 4X4 QUAD
My Ac Blows cool air not cold on hot days. I have added a can of freon but still the same results.
front cold air IS about 50 degrees. All the vents work top and bottom.
WHEN i first got the RAM it was so cold on long drives it would freeze up and would have to pull over so it would un freeze.
I was able to find a bulletin on a fix for the freezing was to add a resistor in series with a wire on the ac controls to slow down the compressor to cycle on off more. That helped on the long drives.
But getting in the RAM now and just seems it could be colder.
The compressors stays on pretty much not much cycling.
Added 1 can of freon not much difference in temperature .
I measured with a digital thermometer and at the vents about 50 degrees.
Checked pressure with gauges and the low side about 37 and when compressor kicks in goes down to about 22 then back up to 37. High side was around 200+
Just cant seem to get the ac to get colder!!!!!!!!!!!!!!
Any suggestions??
dss56 is offline   Reply With Quote
Old 05-08-2018, 04:25 AM   #2
Is the condenser fan working when the compressor is on?
If the fan is working and the pressure are low like that the charge is low and I suggest taking to a shop to find the leak the evap core is very common leak point on the Rams. The system may also just need a good vacuum pulled on it air and moisture can make the system run warmer than normal
Old 05-08-2018, 07:57 AM   #3
xtremwlr's Avatar
You sure the recirc door hasn't broken and is blocking airflow from the HVAC fan in the cab?
Old 05-08-2018, 09:30 AM   #4
Old 05-08-2018, 01:58 PM   #5
David
ATXHEMI's Avatar
This happened on my 05.
Old 05-08-2018, 02:10 PM   #6
xtremwlr's Avatar
Mine too, that's why I asked.
Broken recirc door, laying on top of the blower fan.
Fixed door.
Old 05-12-2018, 09:10 PM   #7
I had a similar problem. I started by throwing the cheaper parts at it first, but there are so many parts involved. I then had my system evacuated and the proper am put in. It's not a good idea to just start putting cans of freon in since it will probably lead you back to the start. Mine worked great for 2 weeks. Then I got an evaporator temperature sensor to put in the core and as I started taking things apart I found the climate control module not plugged in all the way. Corrected and works perfectly. I got lucky. Apparently it had the recall or 3rd party fix on the doors and they did everything but plug it up properly. I have thrown a lot of money at Mopars before and it usually ended up being simple.
xtremwlr likes this.
Lil Red 78 is offline   Reply With Quote
