Air Bag light on after installing new Recirc door - Hemi Truck Club
Old 10-13-2014, 07:16 AM   #1
Hey guys,
I went and installed my new Recirc door today,and now the Air Bag light is on,and I can't get it off.
Here's what I tried so far: Disconnected battery,pulled the 2 air bag fuses (not blown),pulled dash control panel(where your climate controls are) off and rechecked and made sure everything was plugged in(it was). and left the battery disconnected for about a half hour (in hopes it would reset),and checked plugs underneath the seat(in case I bumped them).
Has anyone had this problem? or know how to reset this ?
Thanks in advance ...
OverKill is offline   Reply With Quote
Old 10-13-2014, 08:46 AM   #2
Question
MAY be a dealer situation since the GOVERNMENT is involved with safety and emissions systems...this is purely a guess on my part...someone on here with past experience will solve your dilemma .
Old 10-13-2014, 09:20 AM   #3
Matt
MANual_puller's Avatar
I did the recirc door on mine after it broke randomly, I had no such problems on mine afterwards....airbag light is probably unrelated to recirc door unless a wire got pinched somewhere during installation.....
Old 10-13-2014, 06:11 PM   #4
What year truck?
Old 10-13-2014, 08:49 PM   #5
Is the airbag itself plugged in above the glove box?
May need a scanner for this one that has airbag access
Old 10-15-2014, 08:17 AM   #6
Red,
It is 2004
Old 10-15-2014, 08:21 AM   #7
Charged,
I didn't remember seeing a plug there in that spot. Only remember seeing a bundle of wires there running across the top of the dash. Is there a plug above the glovebox? If so ,I may have bumped with my hands(loose), as it is a tight spot...
Old 10-15-2014, 08:27 AM   #8
The service manual will tell you where the plugs/connections are located. At least being a 04 it should be a little easier then a newer one to trouble shoot. sorry no help here...Good luck
Old 10-15-2014, 10:19 AM   #9
Also make sure all your grounds are hooked up down by the kick panels.
Old 10-15-2014, 11:34 AM   #10
Found the yellow plug above the glovebox. Wasn't disconnect,but I made sure it wasn't loose or anything..
Bout to give up,and take it to a shop.
Is it possible they could clear the air bag light,and it not come back on?
All i did to work on the recirc door was disconnect the battery to disable the airbag cause I was working in that area,to be safe.
Could it be cleared,like a check engine light ? or when the airbag light comes on ,you 100 percent have a problem?
Thanks guys for your help
