2008 Hemi Randomly Stalls*HELP* - Hemi Truck Club
Old 02-08-2018, 08:39 AM   #1
Supreme Member
Stutz's Avatar
Iv'e been having a problem for a couple years now and need to correct it. 2008 1500 SLT. It will randomly stall when I come to stop or back out of the driveway. Basically, low RPM operation. It always starts back up. It doesn't happen all the time. It doesn't happen in the summer very often unless the system is under heavy load (AC running, etc). It happens A LOT in the colder weather. Also, it has never thrown a code. I have taken it into the dealer for them to troubleshoot. They couldn't find anything wrong, so they reprogramed the Throttle Body (since I told them I usually take it off to clean it every other oil change).
2008 Dodge Ram 1500 SLT 5.7L Hemi.
SRT Ram Air Hood (Ducted Volant CAI)
305/55 Nitto Ridge Grapplers.
Hellbent Steel 2.5" Level Kit (Add a leaf in rear)
Blacked out (De-Badged)
Bilstein Shocks all around
http://www.flickr.com/photos/stutzenstein/6132876102/
Stutz is offline   Reply With Quote
Old 02-08-2018, 08:43 AM   #2
CavRam's Avatar
How old is your battery?
2014 Ram 1500 Express
Old 02-08-2018, 08:51 AM   #3
Supreme Member
Stutz's Avatar
2 Years. I replaced it because when I slow down some times I get a flicker in my headlights and thought it might be time to replace it....I still get the dimming headlights.
Old 02-08-2018, 09:29 AM   #4
CavRam's Avatar
Our trucks do very weird things if the battery is not A #1 in shape. If your lights still dim may be time to check charging system.
Old 02-08-2018, 10:55 AM   #5
Supreme Member
Stutz's Avatar
Thank you. I will look into the charging system for sure, but I don't think that it has anything to do with the stalling. It almost seems like an airflow or fuel flow issue. I am just confused why it only happens in the cold.
Old 02-08-2018, 11:01 AM   #6
CavRam's Avatar
My 04 did occasional crazy stuttering/stalling and gauge things until I put a good strong battery in and it cleared right up. Not saying that your symptoms couldn't be an air/fuel thing.
Old 02-08-2018, 08:40 PM   #7
In cold weather is there a possible amount of time it happens at also like 30 secs 1 minute type deal or just at idle and randomly.
Old 02-09-2018, 05:46 AM   #8
Supreme Member
Stutz's Avatar
No set amount of time. In Sept I remember it happened after I got off of the highway and hit a drive-thru. I never shut the truck off and pulled up to check traffic before making a right turn and boom, it stalled. It was 70 degrees F that day and I had been driving for over an hour. In the cold it will stall at a traffic light and then not at the next. I can usually feel it about to happen and slip it into neutral and it won't stall. Again, it never throws a code and always starts back up.
Old 02-11-2018, 04:55 PM   #9
Weird issue there and no codes at all
Old 02-12-2018, 08:32 AM   #10
Supreme Member
Stutz's Avatar
No codes. Here is video of it happening.
https://youtu.be/iZMlcZ-pCZc
