04 Power steering pump leaking - Hemi Truck Club
Old 07-05-2016, 09:29 PM   #1
nsorenson's Avatar
I know its just the line but I see there's a couple different options. How do I find out if I have a conventional pump or hydroboost pump. If it helps my build date is 06/04.
Old 07-05-2016, 09:34 PM   #2
Hydroboost is a hydraulic brake unit on the firewall. Look on the driver side of there is a big round drum looking thing then it's normal/conventional steering!
Old 07-05-2016, 09:46 PM   #3
nsorenson's Avatar
I'll check that out when I get back from work Saturday! I appreciate it I was going to order a pressure line ahead of time but I wasn't 100% sure what line I needed. Thanks!
Old 07-05-2016, 09:59 PM   #4
Have you tried just putting a hose clamp on it?
Old 07-06-2016, 04:17 AM   #5
nsorenson's Avatar
I haven't got under there to see exactly where its leaking at yet. I just noticed a puddle the other day in the driveway and then last night I refilled the Reservoir and it was coming out as fast as I was putting it in.
Old 07-06-2016, 06:24 PM   #6
Often a great, cheap, easy and better than factory solution .
Old 07-06-2016, 11:29 PM   #7
Mine started leaking the same week as a friend of mine's did. I put a clamp on mine and he put a new R&B on his. His still leaked.
Old 07-07-2016, 05:37 AM   #8
nsorenson's Avatar
Worth a shot. Just wasn't sure if that would work for pressure side
Old 07-07-2016, 05:51 AM   #9
It won't for the pressure side of that's the leak side. The return lines leak all the time and a clamp is usually the fix for them. I'd its pressure you will need a line or rack whichever is leaking.
Old 07-07-2016, 06:50 AM   #10
CavRam's Avatar
good read, had the same issue on my 04
http://www.hemitruckclub.com/forums/...ck-4855-2.html
2014 Ram 1500 Express
