03 Hemi 5.7 Timing Chain Install/Replacement - Hemi Truck Club
Old 04-23-2016, 01:47 PM   #1
I am replacing the timing chain on my 03' Hemi 5.7. Is there any advice before I take this project on that I may not be aware of that is a good need to know?
Thanks,
Chase
cornbread mafia is offline   Reply With Quote
Old 04-23-2016, 02:01 PM   #2
Talking
cornbread mafia
You will find a number of unique characteristics associated with the pleasure of owning an '03...someone should be along soon to help you . There are many successful '03 owners here with HTC .
Old 04-23-2016, 02:33 PM   #3
I think it's pretty straight forward with the HEMI
Old 04-23-2016, 02:41 PM   #4
Old 04-23-2016, 04:31 PM   #5
Welcome to the forum, always glad to see 03's join up.
Timing chain is straight forward. It is also an opportunity to upgrade the oil pump. But the pan will need to come down for the oil pump. Take pictures how the marks line up before and after in case you start second guessing if it is lined up correctly later...
Old 04-23-2016, 04:39 PM   #6
Enormous Member
Hugh Jassole's Avatar
make sure you remove the bolt in the back of the AC compressor, I learned the hard way
My other truck is an R/T
Old 04-23-2016, 04:48 PM   #7
Yes the AC compressor bolt. Make sure to double and triple check the timing chain alignment prior to assembly. You don't want to have to open it back up. The oil pan can stay on for the chain swap it's just a tad tricky getting the pickup Tibe bolt out without dropping it.
Old 04-23-2016, 04:53 PM   #8
Ahhh yes the hidden bolt. Many of us have broken AC compressor.... It's behind the compressor, bolts to the head....
Current 1/4 mile [email protected]61mph (2018)
Old 04-23-2016, 07:11 PM   #9
Queen Kima - Whemi BOD
Mrs.Studmuffin's Avatar
Old 04-24-2016, 08:26 AM   #10
Welcome to HTC.
