03 fuel pressure gage readings? - Hemi Truck Club
Old 02-03-2014, 12:58 PM   #1
Ok this is for those who have fuel pressure gages. We know the 03 is setup for 48psi and 04+ are 58psi. A little history, I run a 05 pump @ 58psi and had no problems with DTC "rich condition" using the OEM PCM, Then I installed the Megasquirt stand alone tuner and have now removed it going back to the stock OEM PCM. The problem is I am now getting a DTC for rich condition and my LT fuel trims are pulling fuel at -20 + with fuel pressure showing an erratic 55-66 psi. My question is have I simply trashed the fuel regulator or is there something else causing the problem? What pressure are you guys seeing on your gages? My AFR is showing richer then normal running in the 13.5-14.5 range at cruise. Here is one picture just for reference.
Thanks,
Old 02-03-2014, 03:54 PM   #2
I doubt the megasquirt had anything to do with the trims the 03 PCM just is not use to that much extra fuel and before you were just lucky I guess not sure
The fuel pressure is normal 56-64psi from what I have seen at work I run 56-58psi on my setup
Old 02-03-2014, 06:34 PM   #3
Haha lucky I've never been.
I agree, running the MS doesn't affect the current trim problem. I just need to get the pressure down so the 03 PCM tune can deal with it. When you observe the gage while running is it a bit erratic or is it a steady reading?
Thanks,
Old 02-03-2014, 06:51 PM   #4
Installed twin oem fuel pumps with regulators. Each pump supplies a fuel rail. Just a steady 50 psi fuel pressure under wot. But, will need to raise the fuel pressure in the future.
Old 02-03-2014, 10:19 PM   #5
A good guage I have at work has an anti flitter valve so its steady but for the most part steady 56/58
Old 02-04-2014, 07:02 AM   #6
Ok, I see I need to get the pressure down to a more reasonable level for my 03 PCM to handle. Still don't know how the OEM PCM handled the pressure for the year before I installed the MS. IDK....
Old 02-04-2014, 09:32 PM   #7
Just dumb luck the comp didn't set a code for rich anything over 20% at idle it will set it weird
Old 02-05-2014, 12:30 PM   #8
Ugh looks like it's finally time to build my fuel system...
Old 02-05-2014, 02:25 PM   #9
I did a good write up for yah using factory rails or you can change it up a bit
Old 02-06-2014, 07:22 AM   #10
Keith, much appreciate, I remember reading it. Can you post the link?
Thanks,
