03 Cylinder #6 misfire - Hemi Truck Club
Old 02-19-2016, 05:13 AM   #1
HighMileageHEMI'03's Avatar
Hey guys my 2003 1500 truck has been getting code P0306 at random times when I got the truck last year till now and I need help trying to diagnos this. I'll remote start the truck in the morning and sometimes when I walk up to leave my house I can hear the tone of the exhaust and the engine missing pretty good. It's very definent at idle when cold. However when I just get above throttle the missing stops and the engine acts fine. When it's warmed and you let it idle it doesn't miss runs just fine. I checked the spark plugs and fuel pressure in the fuel rail. The engine has 220,000 miles on it so I'm starting to worry that it's a compression issue but the engine doesnt burn oil or coolant. I'm leaning more towards an injector or bad coil pack. Can anyone point me in the right direction? Thanks
HighMileageHEMI'03 is offline   Reply With Quote
Old 02-19-2016, 08:05 AM   #2
Gold-Member
kcd1369's Avatar
Dang! 220K is impressive. Is the engine all original? Or has some work been done on it?
Old 02-19-2016, 08:25 AM   #3
Motor is all original just oil change every 3,000 miles just Valvoline and Fram filter. It's on it's 3rd transmission and the entire rear axle was swapped out for a salvage.
Old 02-19-2016, 08:29 AM   #4
Old 02-19-2016, 09:03 AM   #5
- Hope it is nothing too serious .
Old 02-19-2016, 09:11 AM   #6
Gold-Member
kcd1369's Avatar
I had to rebuild my engine. Was killed by my son. (lack of maintenance) I had the tranny done while the engine was out as well. It wasn't having any issues, but it sat for 3 years while the truck was dead so I figured I would start with both as new again.
What happened to the rear? Mine has been replaced as well, the pinion nut came loose on the interstate and everything inside got pretty tore up.
Old 02-19-2016, 11:51 AM   #7
Lol yeah sounds like kids. I'm actually 17 years old, Ibought the truck when I was 16 from my dad who had blown up the transmission for the second time. I bought a salvage transmission because I didnt have the time to rebuild the trans and then after driving it the pinion bearing was whinning pretty bad up to speed. I pulled the cover off and discovered the teeth of the spyder gears and main gear on the diff were chipped pretty bad. I had 3 days to get it set to go camping 300 miles so I figured I didn't have the time or money to rebuild it and I wanted a limited slip to replace the open diff. I bought a salvage rear axle for $700 that came with the stock Chrysler LSD 3.55 gears and the thing has been bulletproof since. I tow LOTS of stuff for myself and family and friends. The truck is an excellent work horse. My dad is trying to get me to ditch the truck because of the high mileage but I want to restore the truck after a while. I'm trying to get as much life out of this engine as I can it's got plenty of power for what I need.
Old 02-19-2016, 11:56 AM   #8
When I get home I think I'll do a compression test after I let it cool down and let the rings set. I'll let you guys know whats up, hope it isnt anything too bad.
Old 02-19-2016, 12:52 PM   #9
Move the coil and the injector to another hole and see if the same problem happens on a diff cylinder. Compression doesn't normally come and go that's an all or none thing for the most part. If you move the coil and the injector and still have the issue it could be a lifter or the rocker arm possibly worn out. Let us know what you find.
Old 02-19-2016, 01:54 PM   #10
Alright thanks. These are the plugs in cylinder 6. I'll try swapping that coil with cylinder 4 and see what happens. 14559152773451672279984.jpg
