Trailer Brake controller, How do I know if it is working? - Hemi Truck Club
Old 08-04-2020, 08:12 AM   #1
Hi, I have a Tekonsha unsure what model but I can check later today, It is just a basic slide controller, I hooked up a trailer that has Electric brakes but the controller didn't do anything no lights lit up on the controller even if I slide it manually. The trailer I used may not have working brakes so It was not the best one to try ( Trailer is going though a overhaul ).
How can I check the controller with out a working trailer hooked up?
Should it light up if I slide the slider over with nothing hooked up?
Any and all tips would be great .
Thanks
2004 Ram 1500 with Factory Tow Package.
Old 08-04-2020, 09:52 PM   #2
Ok first off does the controller have any lights? If it does it’s most likely a full on light meaning there should be a switch on the controller for you to manually go full brakes.
When manually operating the controller you can test the brake power wire at the back of the truck. When fully on manually overriding it with the lever you should be getting battery voltage on that pin. Also make sure you have a good ground on the ground pin.
Old 08-05-2020, 07:15 AM   #3
I have a similar controller to this,
https://www.tekonsha.com/products/br...s6vqgsUyhEAAA1
So I can have someone slide it over manually and I can use a volt meter to check the correct pin in the back?
I am sure I can find a pin out diagram on the net to find correct pins.
Old 08-05-2020, 07:14 PM   #4
I figured it out today and the issue is in the trailer, I used a volt meter and a test light and everything on the truck side is working as it should and with the test light the controller also lit up. The Controller needs resistance to light up.
Now I need to figure out how to wire the trailer up correctly.
Old 08-07-2020, 02:43 PM   #5
How does the following plan sound,
I'll get the Brake kit and the junction box linked to below.
I'll run 10 Ga blue wire to the brakes along with white ground or get a duplex wire in a jacket but I won't run across trailer from brake to brake I'll do a home run to junction box from each side.
I'll then use a 14 gauge duplex jacketed wire and run to each tail light and then a single wire to each marker, I believe the lights are all self grounding. I gues I'll need to run a ground from junction to trailer as well. I think running home runs will eliminate a few splices.
https://smile.amazon.com/dp/B0098M5L...v_ov_lig_dp_it
https://www.etrailer.com/Wiring/etrailer/e99011.html
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
