Spring Clamps or Overload Spring removal? - Hemi Truck Club
Old 02-15-2005, 06:41 PM   #1
I just purchased the BellTech shackles and Nitro Shocks for my 04 Quad. I've been reading alot about the spring clamps in the front and the rear shackles. Also read about removing the overload spring instead of using the spring clamps. I'm sure the spring clamps would be an easier process but heard that removing the overload spring improves the ride. Anybody have experience w/both?
vthemi is offline   Reply With Quote
Old 02-15-2005, 07:32 PM   #2
Removing the helper spring will drop the rear a tad more than the leaf spring clamps will... but forget about carrying any large load in the bed, or towing more than a Jet Ski afterwards. Not sure if the ride would be any better than with the spring clamps.
The thing I like about the spring clamps is if I decide to carry a big heavy load, it takes two seconds to remove the spring clamps!
Old 02-15-2005, 08:37 PM   #3
MoneyHSK's Avatar
WOW MrHemi, you can get them off in 2 seconds!
Takes me at least 10-15 minutes! LOL
You ever think of trying out for a Nascar pit crew!
MoneyHSK is offline   Reply With Quote
Old 02-15-2005, 10:18 PM   #4
That is a very good point about returning the vehicle to stock. Although I don't tow or haul anything heavy it's always a good option to go back to stock as quickly as possible (2 seconds) . Thanks for the advice, I'll post some pics when I'm done.
Old 02-27-2005, 12:25 AM   #5
Well, I finally had some Belltech shackles installed on top of Gabriel MaxControl shocks all the way around. In my first post I had bought Belltech Nitro drop shocks. Unfortunately when I ordered them they only sent me one because they were out of stock. Not a big deal until I found out that they were 3 weeks out from the Manufacturer getting them. First of all let me tell you the ride w/the new shocks is like night and day. There's this lane on I80 (the one the Big Rigs always use) out here that has always been bouncing me around. Not anymore . I think the stock shocks probably rebound too slow. Anyways now the ride is all good. As far as the shackles go, before I put them on the measurement from center of rim to lip of wheel well was 23 3/4. After the shackles it measures 22 1/4, just 1 3/4 inches from level w/the front!!! I'm going to clamp the front of the leafs tomorrow (wife had enough of HEMI attention today). I'll post some pics when the weather gets better out here in N. California.
Old 02-27-2005, 06:10 AM   #6
You'll get close to another inch with clamping the front of the leaf springs... and almost 1.5 inches if you clamp front and back
Old 02-27-2005, 11:39 AM   #7
jlhram's Avatar
I used the ground force drop shackles and removed the center leaf spring, made it level. I also have bilsteins all around and a hellwig rear sway bar. I like the ride and I have hauled about 400lbs of concreate with no problem.
jlhram is offline   Reply With Quote
Old 02-27-2005, 06:43 PM   #8
Do the drop shackles reduce your payload? The *** end of my QC could come down at least 2" but I don't want to lose too much payload capacity. I'm doing alot of reno's to the house and am constantly hauling something. Last year I made 6 runs to the recyling yard, carrying busted up concrete. The scales had my heaviest load at 1700 pounds. She rode smooooth and didn't bottom out once. These truck can haul more than ***!
Northemi is offline   Reply With Quote
Old 02-27-2005, 07:38 PM   #9
The drop shackles won't reduce your payload all that much... it's the spring clamps that will decrease your payload capabilities (but not enough to really worry about). I should say though - if you're hauling around up to 1700 pounds, I'd probably just stick with the drop shackles!
Old 02-28-2005, 10:03 AM   #10
I guess I spoke too soon. Although the ride is great w/the new shocks I definitely hear a knock from the right rear when I go over a bump. I haven't even clamped down the leafs yet. Any ideas to what it may be? I notice it at lower speeds not on the Highway.
