Is this okay???? Please help! - Hemi Truck Club
Old 06-08-2013, 09:46 PM   #1
Unhappy Is this okay???? Please help!
When I tow my 5th wheel on the interstate the RPM ranges from 2500rpm to around 4100rpm. The speed is between 60mph-75mph. The RPM tends to stay in the upper 3000 range most of the time. I live near the mountains so the grades are long and plenty. Coming back from an extended trip today I noticed the Transmission temp was steady around the 220 range. I tried the tow/haul switch but that seemed to make the RPM's even higher and the shift was around the 4200-4500 range and then went to 2000 and immediately back to 4200. I fear I doing major damage to my transmission.
What would be a "normal" range of RPM for a setup like I have? I don't know, maybe a 3/4 ton is in my near future if I want to keep my 5th wheel.
Do any of you have advice or a possible solution? I thought about a tuner card but then the question is which one and will it really help?
Here is my setup. 2009 SLT Quadcab 4x4 5.7L Hemi with 3.55 gears. Tire size LT275/65R20.
All help will be greatly appreciated as long as it doesn't tell me my truck sucks and I need to buy a diesel.
dkurban is offline   Reply With Quote
Old 06-08-2013, 10:24 PM   #2
It sounds like your truck is a bit light for what you are asking of it. But I would rcommend slowing down to a steady 55mph and run with the O/D off. No prolong 4000> pulls. The 3:55 gear is your main problem and a 4:56 would solve most of you tow problem. Good luck...
Old 06-08-2013, 11:15 PM   #3
It may be slipping a tad to those rpms are kinda high especially for the gear ratio with a 5th wheel you should have a 2500 or bigger truck though that's maxing the tow rating out I beta
Old 06-08-2013, 11:17 PM   #4
My dad always told me to get the right tool for the job. If you do allot of towing, especially in the mountains. You need a truck that's built for it. A 2500 or even a 3500 Dodge Ram is what you need.
Old 06-09-2013, 09:47 AM   #5
Thanks for the replies guys. I'm going to look at 3/4 tons today. I should be set by the middle of the week.
Old 06-09-2013, 09:54 AM   #6
AlbertaHemi's Avatar
But I would recommend slowing down to a steady 55mph and run with the O/D off
and you won't be that guy trying to change tires on the shoulder
Dave.
HTC MEMBER #2460
Old 06-10-2013, 04:23 AM   #7
Farrrrrr East Coast
NewfieBullet's Avatar
thats all i do when im movein the travel trailer. take my time...but i dont see those rpms...3400 was the most i seen and that was slightly gaining speed on a hill.22-2300 was usually enough to hold speed on many slight hills and up grades.
Old 06-13-2013, 02:33 AM   #8
rdsetgo's Avatar
Try to find a 2012 or older if you want to mod your truck... EPA fixed so that 2013 and up you can't really do the good mods to them!
CURRENTLY OWN 2012 Ram 2500 4X4 Crew Cab Laramie Cummins and 2013 Dodge Durango AWD Citadel HEMI!!
GONE 2010 Dodge Ram 2500 4x4 Big Horn Crew Cab HEMI, 2011 Dodge Durango AWD Crew HEMI, 2007 Dodge Ram 1500 Big Horn 4x4 Quad Cab HEMI, 2008 Dodge Durango SLT 4x4 HEMI, and my First 2004 Dodge Ram 1500 Quad Cab HEMI
2010 HTC NASCAR Champion
April 25, 2007!!
Old 06-13-2013, 08:14 PM   #9
KevDog's Avatar
This may not be a very popular reply on the HEMI forum...but to me it sounds like you really should have a diesel truck. Every time I tow my camper, I wish I had gotten one. How much does your camper weigh?
HEMI HAULER: Hauls butt...and occasionalyl, an 6900lb camper!
2018 RAM 1500 Sport Quad Cab with Night Package
K&N Cold Air Intake
KevDog is offline   Reply With Quote
Old 06-13-2013, 08:33 PM   #10
rdsetgo's Avatar
There a few of us that have went to the Cummins on here! But I still own a HEMI in the wife's 2013 Durango!!
April 25, 2007!!
