7 round connector - Hemi Truck Club
Old 07-28-2015, 08:08 PM   #1
Gold-Member
kcd1369's Avatar
7 round connector
I have as questuon, does anyone know what pin should have constant 12 volts?
There should be 12 volts on one of the pins that would be used to charge the trailer battery. I only found one fuse marked trailer power, its a 40 amp fuse.
Any help is appreciated.
Old 07-28-2015, 09:04 PM   #2
Here you go.
Old 07-28-2015, 09:06 PM   #3
Top center around the clock then center.
12v
Right turn
Trailer brake
Ground
Left turn
Parking
(Center) reverse lights
Old 07-29-2015, 05:29 AM   #4
Gold-Member
kcd1369's Avatar
Thank you. That is perfect.
Old 07-29-2015, 08:48 AM   #5
Old 07-29-2015, 04:45 PM   #6
There is a lot of diagrams on the internet. Here's one. Seven pin is near the bottom.
Trailer Wiring Diagrams | etrailer.com
Old 07-29-2015, 04:53 PM   #7
Gold-Member
kcd1369's Avatar
Thanks Greg. I had a few from the web. But wasn't sure if I had the right one due to power missing an 2 pins. And as Keith pointed out by posting that picture, it is molded into the cover. My problem is I don't have the 12VDC even now knowing the correct pin out. And the fuse is good. All other signals are there. Just no trailer power on the + pin.
Old 07-29-2015, 05:48 PM   #8
You'll have trace the wire. I installed mine myself so I know what to expect. If yours is factory you may have something not turning on. Maybe do a little custom wiring using a relay and fuse of your own.
Old 07-29-2015, 07:09 PM   #9
Gold-Member
kcd1369's Avatar
Greg, do you have a schematic that shows this circuit stock? Is there a relay in this line? Maybe that's my issue if there is.
Old 07-29-2015, 07:54 PM   #10
On my 03 schematic The power (12vdc) starts at Fuse #1 (40a) in the IPM, exits IPM C6-2 RD/OR. Looks like there is a connection near controller) changing wire color to WT/RD. So do you have a WT/RD wire at the rear bumper? If not then you can do like I did and connect to the pos terminal at the battery and use a 40a fuse with a 40/60a automotive relay inline activated by ignition "ON" source. Then run the wire to the rear bumper and connect to the 7 pin connector. When not towing you can remove the fuse or just leave it in... Good luck.
