Hemi dakota - Hemi Truck Club
Go Back   Hemi Truck Club > HEMI Marketplace > For sale
Old 09-29-2015, 09:28 PM   #1
Hemi dakota
Hi all im sad to say i need to part with my project truck. Due to my work schedule being so crazy i am not able to work on it any more. I have lots of parts and accessories to go with it. I have two hoods, one brand new in box and another one in primer. I also have a brand new left fender in box as well as a couple take off fenders from another truck. It also comes with a new non chrome grill to be painted. I also have new backing plates loaded with park brake hard ware to convert it to the rear disk brakes from a 2003. It also comes with a 2003 master cylinder and rear calipers. As for the brakes i have new in box front and rear EBC sport rotors which are drilled and slotted, they also come with EBC green stuff pads. There are also polyurethane rear leaf spring bushing new in box as well. Also new in box is a bolt over billet grill insert. Also have a spartan cam from inertia motorsports for a 5.7L hemi, which is a 214/218 duration set up. Also have new timing cover gasket, 6.1L valve springs and push rods. Also have a set of edelbrock shorty headers. The truck had a 4.7 in it and it has a 45rfe auto. I purchased engine mounts from another forum from a member who had done the conversion already so it was an easy bolt in. currently the engine is bolted to the transmission and to the mounts, a friend redid the oil pan and pick up tube to clear the front axle. It also had a new rack and pinion bolted in before the new engine was set in. I also installed 4.10 gears front and rear with an auburn pro series limited slip unit in the rear. Truck comes with the factory wiring harness and pcm for the truck, the engine came with the engine harness, hemi pcm, and oxygen sensors. i am probably forgetting some things to list as well. but it will attach pictures of it. the truck has a clean TN title and i have the title in hand.
I am asking $7,000 for everything together, or best offer. please post or pm for offers or with questions.
2000 dodge dakota quad cab 4x4 with 4.10 gears and an auburn lsd in rear axle.
soon to have an 2004 hemi engine swap.
dakota dave is offline   Reply With Quote
Old 09-29-2015, 09:33 PM   #2
here are some more pictures.
Old 09-30-2015, 08:40 AM   #3
What year PCM?
Old 09-30-2015, 09:34 AM   #4
ROLLING THUNDER's Avatar
Hate to hear you are unable to finish your project. I understand completely because I have been there. Sounds like a good deal for someone who needs it. Best of luck my friend.
Old 09-30-2015, 06:35 PM   #5
Old 09-30-2015, 07:30 PM   #6
its a 2004 pcm, the engine and hemi harness came from a wrecked 04 1500. i have a card with the vin of the truck it came out of. i also have a APPS for the truck as well, its the style that mounts under the battery box that the manual throttle cable attaches to.
Old 09-30-2015, 07:56 PM   #7
Gold-Member
kcd1369's Avatar
Def. stinks that you can't finish the way you wanted to.
I can relate. But Good luck.
kcd1369 is online now   Reply With Quote
Old 10-01-2015, 09:56 AM   #8
Exclamation
Old 10-07-2015, 11:26 AM   #9
Just bumping my post, I'm not firm on the $7,000 just trying to get what I can, feel free to make an offer.
Old 10-14-2015, 07:57 AM   #10
Vladek's Avatar
sucks that life gets in the way. wish i had the extra $$$ i need the mounts and oil pan for my swap still.
Vladek is offline   Reply With Quote
