03/04 Intermediate top harness - Hemi Truck Club
Go Back   Hemi Truck Club > HEMI Marketplace > Wanted to buy
Old 08-07-2016, 02:50 PM   #1
I'm looking for what I'm calling intermediate top harness plug. The 03 and 04 and maybe 05 has a plug on the drivers rear of the intake area. The harness has the pcm plugs on one end and then plugs into the fuel injection and ignition harness. I don't need the harness but looking for the plug with about 6 inches of the harness wiring. I have a 07 harness and it doesn't have the plug. So somewhere between 04 and 07 they removed the plug making the harness one piece. If you have a donor harness let me know...
Thanx
Old 08-08-2016, 08:29 AM   #2
I'm surprised no one has a donor truck sitting around or at least a spare wiring harness. This plug is generally not used in upgrading the ignition coils. And if you are into modifying your wiring, I recommend having a spare harness to rob both wires and plugs from. It will save a ton of money. Also it's good to have a electrician's booklet of sticky numbers to label wires. This really helps with keeping track of wires.
Old 08-09-2016, 10:23 AM   #3
Did a little research and found the plug is "C106". Since I've gotten no response from anyone identifying the plug becomes meaningless. So if by chance anyone has a source for repair pigtails, post up the info....
Old 08-09-2016, 05:00 PM   #4
I don't have any laying around that's for sure. Will look around and see if I can find something. How many pins are in it?
Old 08-09-2016, 05:21 PM   #5
Thanks Keith, it has 16 pins. 2x8 rectangular shape. Also looked for repair pigtail and not surprisingly "not available". I believe, the 03, 04 and 05 all have the connector.
Old 08-09-2016, 05:41 PM   #6
Yes they all do have that connector
Old 08-09-2016, 05:52 PM   #7
Excellent, that will widen the search.
The harness I'm currently using is chopped up pretty good from first changing the coil plugs and then the Megasquirt install. I've got a 07 harness that doesn't have the plug and I want to redo a complete harness to just be a plug and play.
Any help is appreciated.
Old 04-09-2017, 02:36 PM   #8
I'm still looking for the 16 pin connector (03-05) that the coils and injectors connect to. It's located at the top, rear of the engine on the driver's side. It's rectangular with 2 rows of 8 pins. Would like both sides (male and female).
Thanks,
