Well, my engine is hosed - Hemi Truck Club
Old 12-24-2011, 12:56 PM   #1
MikeHTally's Avatar
... and flushed. Almost belted, but the OEM belt showed no cracks or splits, so it went back on the motor.
Be warned - the Dayco 72184 lower hose DOES NOT fit. The hose that runs from the block to the radiator is at least 3" short. I had to put the old hose back on so I could finish the flush 'n' fill. Also went back to a 203 'stat to get more heat this winter.
Old 12-24-2011, 12:56 PM   #2
MikeHTally's Avatar
Old 12-24-2011, 03:58 PM   #3
It is past time to do mine, but I seemed to have them off so often and check them each time I can't bring myself to change what looks like a perfectly good hose.
Old 12-24-2011, 06:10 PM   #4
Retired BOD - Doug
RANCHER's Avatar
Old 12-24-2011, 07:17 PM   #5
"Bob"
motorscooter's Avatar
Old 12-25-2011, 02:43 AM   #6
Mr. Freeze
VA4MEDS's Avatar
Maybe you should have used a hose stretcher?
Old 12-25-2011, 03:30 AM   #7
HTC.com Titan Killer Club
Member # 17
Old 12-26-2011, 07:14 AM   #8
Jim-CO Chapter Dictator
RockyMtnXpress's Avatar
Old 12-26-2011, 06:29 PM   #9
Old 12-26-2011, 06:58 PM   #10
Freeze's Avatar
Maybe you should have used a hose stretcher? dunno
Jay has one you can borrow!
