U0114 code fault - Hemi Truck Club
Old 08-14-2012, 07:14 PM   #1
Team Spankintime
michigansrt8's Avatar
Is it safe to drive with this code fault? I have read that this code means LOST COMMUNICATION WITH FINAL DRIVE CONTROL MODULE. My traction control is also not working and it now runs rear wheel drive now, no longer awd anyone have advice on what to do?
2008 Jeep GC srt8 6.1L HEMI
(6.1L 370 HEMI Block bored and stroked to a 426 stroker, ST-3A camshaft,148mm throttle body, Kennebell 2.8 supercharger, blower, AtI harmonic balancer, Kennebell serpentine belt tentioner, idler kit, engine serpentine belt tentioner, 80lb FORD racing fuel injectors, kennebell fuelrails, E85 capablefuel system, paramount stage 2 transmission, paramount high torque transfer case, double crank vents, Kooks custom exhaust headers, coffin mufflers, 6 point roll cage, 5 point harness, adjustable rear shocks,drilled and slotted roaters, CA91 650rwhp, E85 787rwhp tune.. installed and tuned by spanktime motors, Team Spankintime member #6 of 10
()-650rwhp CA91
()-787rwhp E85
my Jeep srt: hunts for camaro's, skins cobra's, preys on vette's
2006 Dodge Charger 5.7L Hemi R/T- Stage 2 AFE CAI
michigansrt8 is offline   Reply With Quote
Old 08-14-2012, 07:14 PM   #2
Team Spankintime
()-650rwhp CA91
()-787rwhp E85
Old 08-14-2012, 07:38 PM   #3
HemiByrd's Avatar
You might try reseting the code with a scanner or a tuner if you have one. If you don't have access to those try disconnecting the battery negative for about 30 minutes then reconnect it and see if the code comes back.
'05 RCSB 1500 SLT 5.7 Hemi Ram - Airaid Long Snorkel UBI CAI - Taylor shorty wires - MSD Coil Packs – Magnaflow y-pipe - Flowmaster 50HD - Superchips 3865 - Motive 4.56 gears - Detroit Truetrac - PML differential cover – some good Karma 8.87 ET
Old 08-15-2012, 06:47 AM   #4
I agree with Dave, I know nothing about AWD, but before mechanically disablying the axle I would have it diagnosed to see what failed. Maybe nothing more than a electrical connection/sensor. When you drive them hard they need lots of maintenance, differentials and transmissions being the main issues with our trucks.
Old 08-15-2012, 01:24 PM   #5
Board of Directors-Bill
arocketman's Avatar
‘05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 08-23-2012, 03:53 PM   #6
boedacres's Avatar
just a wild guess but try to rest it first. it set a code because either the front or the rear axle was spinning faster than the other all wheel drive needs to be together or the computer has a fit.
Old 08-24-2012, 06:17 AM   #7
Team Spankintime
Ill try those after I replace the starter, the beast won't start now, just paid almost 300 for a new starter. Hopefully I can get mine towed by a friend today.
()-650rwhp CA91
()-787rwhp E85
Old 08-24-2012, 06:48 AM   #8
U0114 code fault
I would make the service manual my friend and read up on your specific model. You will more than likely fine that there is a starter relay and other electrical components that could cause the starter problem. Part of my trucks security is installing a switch controlling the starter relay. As for the UO114 code, figure out what sensor actually throws the code and trouble shoot from there.
