Trouble with rough idle - Hemi Truck Club
Old 05-09-2012, 06:12 AM   #1
WagzHemi4x4's Avatar
Hey guys hoping some one can shed some light on this problem, i have a 03 Ram 2500 5.7 Hemi, i got a check engine code the other day P0300 random misfire code and i looked up what it could be and got a laundry list of things. I have replaced pretty much everything on that list spark plugs, wires, coil packs, pcv valve, camshaft position sensor, fuel vapor canisters, fuel vapor leak detection pump and fuel pressure regulator. the only things i have not done is o2 sensor, fuel injectors and valve springs but i dont know if it is any of these parts that i have not changed yet. Im into this fix $475 and still having the problem. To start the truck i have to hold my foot down on the pedal just a bit to get it started once its started i have to keep it above 1500rpms or it just dies. Also i don't think its the valve springs because there should be loud ticking coming from the engine when running. If some one could help shed some light on this problem so i can have my truck back it would be greatly appreciated thank you so much.
WagzHemi4x4 is offline   Reply With Quote
Old 05-09-2012, 06:12 AM   #2
Old 05-09-2012, 01:59 PM   #3
I have reponded to this thread twice and both times my reply disappeared. Anyway my guess is you have a broken valve spring. I recommend pulling the valve covers and carefully check the springs. Good luck...
Old 05-09-2012, 02:59 PM   #4
i will pull the valve covers and check them but im not shure if it is the valve springs because i talked to some one i know that used to be a mechanic and he did say that if i did have broken valve springs that i should be hearing a loud ticking from the rockers having to much play. also i have confirmed that its not just one cylinder misfiring.
Old 05-09-2012, 03:40 PM   #5
I generally agree with your mechanic, however doesn't take much on the hemi to drop a push rod off the rocker and not hear it. Not trying to make excuses but I would check for a broken spring as 03/04 have known valve spring problems. A general misfire code only indicates the engine idle is changing speed outside the set PCM parameter. If it is calling out a specfic cylinder, it may well be injector/coil related as there is no other way to sense specific misfires. good luck..
Old 05-09-2012, 03:40 PM   #6
Ck springs/run compression test!
HTC.com Titan Killer Club
Member # 17
Old 05-10-2012, 05:25 AM   #7
ok when i check the valve springs if i find any broken is there a way to change them in the truck with out removing the heads?
Old 05-10-2012, 06:30 AM   #8
boedacres's Avatar
yes you can you need a overhead valve spring compresser tool like this
http://www.autobarn.net/lisle-59550.html
and you need to put compressed air in the cyl.to keep the valve up.
Old 05-10-2012, 08:21 AM   #9
I used this other style compressor which worked great. There are a couple members who manufacture this style on the side.
http://www.cranecams.com/produ...oduct_detail&p=25310
Old 05-11-2012, 10:38 AM   #10
boedacres's Avatar
thats the one i wanted but couldnt find it at the time they work great.mine worked but its a pain in the butt
