... on a diesel generator.
Our backup generator at work had to start last weekend. After almost an hour, it ran hot and shut off. The vendor determined the oil cooler had failed and let oil into the coolant. They replaced the cooler but then determined the 'stat had failed due to the oil. The 'stat is only about a year old. Can the engine oil cause the 'stat to fail?
