Sea Foam Question - Hemi Truck Club
Old 12-19-2011, 08:38 AM   #1
White Lightnin''s Avatar
Who has used it what are your thoughts. I am running a can through my tank now but have been told by several including someone that works for dodge that I should run it through my vacuum, fuel line, induction etc... what is everyones thoughts and how do I do it exactly... Thanks
http://www.facebook.com/#!/profile.php?id=560679787
2005 Dodge Ram 1500 4X4
5.7 HEMI
Crew Cab
Bright White
40 Series Flowmaster Single In Dual Out
3 1/2" Stainless Steel Tips 45 Degrees to the rear....
Much more to hopefully follow
HEMI ON
"I am not driving fast I am flying LOW"
Giggity Giggity
[COLOR:RED]HTC Titan Killer[/COLOR]
White Lightnin' is offline   Reply With Quote
Old 12-19-2011, 08:38 AM   #2
5.7 HEMI
Crew Cab
Bright White
HEMI ON
Giggity Giggity
Old 12-19-2011, 11:19 AM   #3
MikeHTally's Avatar
I've used it several times. The full treatment seemed to improve the idle and throttle response.
The 'structions on the can are pretty thorough: 1/3 slurped into the brake booster vacuum hose on a warm engine (someone will need to keep it wound up - otherwise it'll try to stall). Shut it off and let it sit five minutes. Start it back up and watch the smoke show. You can also put an appropriate amount in the crankcase and let that sit for a short time before an oil change. It's supposed to clean out any sludge or stuff in the oil passages.
I put a can in the gas tank maybe twice a year. I do the intake portion about once a year. I've only done the crankcase thing twice on the Ram.
Old 12-19-2011, 08:25 PM   #4
Jim-CO Chapter Dictator
RockyMtnXpress's Avatar
I checked out their WEBsite and was actually surprise.
Sea Foam
then click Cleaning Varnish and Carbon Deposits - Fuel Injected Engines.
I always pour some in my gas tank on fill-up (Edit > ) every 6 to 8 months. That was all I figured I needed to do...
Old 12-19-2011, 10:25 PM   #5
Don't blow up your intake..
Mine: 2011 2500 4x4 Crew Cummins. HERS 09 Inferno Red Hemi Crew Cab SLT lone star with brown and tan interior loaded with 3:92s.
Shane is offline   Reply With Quote
Old 12-20-2011, 12:59 AM   #6
I have never used this product. IMO, if it was concentrated enough to actually do what it says it will do it couldn't be sold over the counter. I don't believe in magic formulas.
my 2 cent.
Old 12-20-2011, 03:41 AM   #7
I have heard great things. I am not going to do it myself but have a mechanic buddy that will... It isnt like it is going to do amazing things but even a little improvement for 10 and a 6pack is nice.
5.7 HEMI
Crew Cab
Bright White
HEMI ON
Giggity Giggity
Old 12-22-2011, 11:43 AM   #8
NHHEMI's Avatar
Seafoam is an excellent product. Been using it for years. Only works average in the gas tank but when used through a vacuum source to clean the combustion chamber or in the crankcase to remove moisture, free sticking lifters/valves, or as a mild flush it works great in my experience.
I detail how to do it in this thread. No need to have anyone do it for you. Very easy...
http://hemitruckclub.infopop.c...0035352/m/8730073295
__________________________________________________ __
2011 Jeep Patriot
Latitude
2.4L 4WD
[color:purple]Royal Purple[/color] #1 :thumb2:
Old 12-22-2011, 09:02 PM   #9
NewBlue's Avatar
I've used it to remove moisture from the fuel tank and as a fuel stabilizer. Put it in any gas that will be stored and in any small engine in the fall and run it to get some through the carb. They'll start like a champ in the spring without draining the gas. Better than Stabil.
Never used it in the intake or oil.
Old 01-02-2012, 08:01 AM   #10
zwa21's Avatar
I use it occasionally thru the gas tank.
Once thru the booster. Didn't smoke a lot but some.
Flowmaster Super 40
