changing the gear oil - Hemi Truck Club
Old 09-19-2012, 01:41 PM   #1
EVILRAM07's Avatar
does anyone know how many quarts i will need for the rear and the front .I think i am passed due
New ride
2013 Hemi crew cab sport
Gone but not Forgotten
07 laramie 5.7 hemi 4x4 QC Dynatech supermax headers, 4.56 gears, Vararam CAI, Black magic E fan. Alluminum driveshaft JVCnx7000 head unit 2-12" kicker comp, 2-6 1/2" alpine and 2 alpine 6x9 2 fosgate power amps 800 4 ch. &1500 1ch. 20" rims. Flex a lite E fan..160 db train horn. Diablo with custom tune from HEMIFEVER and White Lightning, Fastman throttle body
EVILRAM07 is offline   Reply With Quote
Old 09-19-2012, 01:41 PM   #2
EVILRAM07's Avatar
New ride
Old 09-19-2012, 03:20 PM   #3
Last rearend oil change I used just short of 2 qts. Front should be about the same.
Old 09-19-2012, 03:39 PM   #4
EVILRAM07's Avatar
thanks greg i couldn't remember how many quarts i bought when we did the 4.56 gears.
New ride
Old 09-19-2012, 03:53 PM   #5
Jim-CO Chapter Dictator
RockyMtnXpress's Avatar
Not knowing where your mileage is, I am going to list them to be serviced, to both front and rear differential at 36,000 miles – 54,000 miles – 72,000 miles – 90,000 miles – 108,000 miles – 126,000 miles – 144,000 miles and so on.
Front differential/axle, hopefully yours is 1500 Ram with a C205F, requires 1.60 liters or 56.00 ounces (or 3.5 pints). This unit requires GL-5 SAE 75W-90 (MS-9763) or equivalent.
Rear differential/axle, again hopefully a 9.25” limited slip, requires 2.10 liters or 72.00 ounces (4.5 pints). This unit requires Mopar Synthetic Gear Lubricant SAE 75W-140 (MS-8985). Limited Slip requires the additive of 118 ml (4 ounces or .25 pint) of Mopar Limited Slip Additive or equivalent < I personally would add this first then gear lube while checking at 4.2 or 3 since the owner’s manual is in a gray area as it states it needs and not as an additional (see below).
All work to be done on a flat level surface and fluid level on the front differential/axle should be even with the bottom of the fill hole and the rear differential/axle should be 5/8” below the fill hole.
That’s all I got!
Old 09-19-2012, 05:38 PM   #6
Birdshot's Avatar
Some aftermarket diff covers are deeper than the stock one also. Which could add to the capacity.
