alternator - Hemi Truck Club
Old 07-17-2012, 09:25 PM   #1
08blueram's Avatar
alternator
Don't know if I am posting this in the right place but here it goes I needed a new alternator and someone nice enough to give a 2005 durango 160amp off a 5.7 will this work on my 08 ram 5.7 thanks in advance nick
08blueram is offline   Reply With Quote
Old 07-17-2012, 09:31 PM   #2
"RANCHER"
alternator
With you being in Florida I would check with the guys in the Florida Chapter. They have done so much work on their engines they can take them apart and put them back together blindfolded.
I think it will work if the mount is the same.
Old 07-17-2012, 10:23 PM   #3
MikeHTally's Avatar
alternator
Probably a direct fit. If my alternator ever goes away a 160 is in the mix. To be sure, check out one of the big-box parts houses and compare part numbers.
Old 07-17-2012, 11:56 PM   #4
08blueram's Avatar
alternator
Thanks I think its a blessing that it went out I need more amps for my cb lol
Old 07-18-2012, 05:16 PM   #5
08blueram's Avatar
alternator
Well it doesn't work wrong plug and throws a code if you change it
Old 07-18-2012, 05:39 PM   #6
MikeHTally's Avatar
alternator
Don't look now, but your CB will never draw enough current to make the alternator break a sweat. Your audio system draws more current.
Old 07-18-2012, 08:20 PM   #7
mindy\s hemi "Satch"
alternator
Just had to replace mine. 2nd time first time was for bearing squeal, never really failed but replaced it anyway. This time for some reason the small connector that goes back to PCM burnt and melted, think diodes shorted. But I went back to NAPA and got replacement for $60.00 as the one I bought from them had a 3 year warranty but the guy at shop called and got me a deal as mine was 4 years, they now offer lifetime warranty. But if anyone can tell me where to get the connector that attaches to the alternator I would appreciate it.
Old 07-19-2012, 06:43 AM   #8
boedacres's Avatar
alternator
dealer
Old 07-19-2012, 12:13 PM   #9
alternator
Brought mine used and still works great after a year.
180a that i believe came out of a 2G Durango w/ dual climate A/C.
Old 07-20-2012, 01:42 AM   #10
08blueram's Avatar
alternator
@mikehtally ill tell when you do cb competition and the set up you run draws around 75 amps you got a little something.more then a regular cb lol I can almost shut the truck off hahaha. The truck is back together good as new new bearings and a little work from the local alternator shop 35$ is bad I don't think
