02-22-2011, 03:08 AM
#15
07 ram 1500 with loose front suspension question
Welcome to the HTC, Coach Bob. I know you have tried to be as specific as possible, but you haven't really narrowed the problem down aside from locating it somewhere in the front steering/suspension. A bad alignment job may cause some of the symptoms you describe. Or, it could be a single support bracket for your front differential. There's a lot that can go wrong w/ IFS. I'd recommend getting under there, hit all the bolts with red Loctite, and reassess after driving it for a while. BTW, the Dodge IFS is VERY sensitive to modification and will be a PITA to align properly if the suspension geometry has changed.
