Well that sucks. I need to go to the track here soon. Going to turn the truck up to 18psi and full send it to get a baseline before tearing into the truck really good.
Guess I will follow you up again, this time we're going for a full Boost 15 psi + Billy has a good handle on the tune! we are messing with the transmission now. I even contacted Clint about giving me a lockout button for torque converter lock up. See if we can get this puppy in the 12.
You should be able to get it there Mark with 15psi boost.
Your not even running lower gear ratio with a stall converter.
I can bring my slicks and all of the tools for you the next time we run at the track. You'll definitely be in the 12's then.
