best time on Lt bridgestone tires - Hemi Truck Club
Go Back   Hemi Truck Club > HEMI | At The Track > Drag Strip | Times, Tips and Tricks
Old 06-05-2011, 01:58 PM   #1
6-5-11 three times second run was the best rolled out about 25 feet then stuck it third hesitated but overal good run with caltracs and tires shell go faster by the way crank bolt cam out litteraly was just sitting in the snout when i got back to truck so not sure if boost dropped off or not was watching afr's
Old 06-05-2011, 01:58 PM   #2
Old 07-27-2011, 01:27 PM   #3
Those are great times Keith. But, your mph truly tells the story here.
I'm sure someone will lone you their DRs or M/T slicks the next Funday Sunday. I'm sure you'll be very close if not in the 12s.
Old 07-27-2011, 06:45 PM   #4
Well I have done some more tuning on the truck had balancer issues last time fixed that and had a little knock found that to be false knock the charger is causing false vibrations only on passenger side called Paxton and was told that the charger can do that on sensitive newer vehicles but anyway I'll be there on sept 11 ready to go I might take Al up on his offer to borrow the tires see if we can't break into the 12s range
Old 07-28-2011, 04:14 PM   #5
Old 07-29-2011, 02:32 AM   #6
Mr. Freeze
VA4MEDS's Avatar
Old 09-09-2011, 10:31 PM   #7
chefred112's Avatar
good luck sunday...I'm heading to our local track as well on the 11th...
__________________________
-fast freddie- 392 hemi :)
Old 09-10-2011, 02:27 AM   #8
Mr. Freeze
VA4MEDS's Avatar
Same to you Freddie
Old 09-10-2011, 12:16 PM   #9
Thanks and same to you
