Upgrading my Roadrunner - Hemi Truck Club
Old 08-08-2007, 11:26 AM   #1
jlhram's Avatar
Hoping to get some recommendations, upgrading from a mostly stock 383, with 906 heads, edelbrock performer intake and holley 670 street avenger carb. biggest complaint is valve train noise so I deffinetly want to go with a roller rocker setup. currently she puts out about 220hp to the rear hoping to get up past 300 on pump gas. Mostly street but wouldn't mind a few passes on the local 1/8 mile track and don't want to embarass myself. Also trying to not have to sell a kidney. So let me know what you think. I allways apppreciate the advice....Thanks ....Jim
jlhram is offline   Reply With Quote
Old 08-08-2007, 12:09 PM   #2
TheBoss's Avatar
There's a guy at the track I've been meaning to talk to that's got a '68 RR with a 383. He's running low 13's high 12's, I'll see when he comes around if I can talk to him and pick his brain a bit. It's nothing that radical either, though it does sound mean.
Old 08-08-2007, 12:59 PM   #3
Hey buddy, I'm very familiar with the 383-440 motors. What you've done so far, are good choices. The stock MoPar distributor is junk, even brand new. Replace it with any aftermarket Dist. A set of headers would be next. As time and money permit, a small Hyd. cam, with about 284 advertised duration, would work well. The heads really respond well to modifications. Installing the 2.14 Intake valve, and the 1.81 exhaust valve will make quite a difference. Good luck, and PM me if I can be of further help.
Old 08-08-2007, 02:29 PM   #4
TheBoss's Avatar
Well... uh... yeah... what he said.
Old 08-08-2007, 05:17 PM   #5
jlhram's Avatar
Thanks for the replys, Jay, I believe the cam I have now is a 484 with a 260 duration. I was told it has a hemigrind cam in it. I'm running a steel crank and forged pistons. Got good compression and oil pressure. The valve train noise has me puzzled , I've replaced lifters once already and it still sounds pretty bad. Last set I put in were made by clevite, gonna pull the valve covers this weekend and see what it looks like. What's a good aftermarket distributor ? Thanks again I'll keep you updated on my progress.....Jim
Old 08-08-2007, 10:19 PM   #6
There should be no valve train noise. Something is wrong. Choices are; 1. Valve train geometry is off. 2. Worn rocker arms/or shafts.#3. and the most likely, the 906 heads where meant for leaded fuel. Unless hardened valve seats where installed, valve recession into the head is inevitable. #4, weak valve springs.
Old 08-14-2007, 01:17 AM   #7
jlhram-I caught this a little late....I like the MSD distributors(pro-billet)with one of their 6-series ignitions boxes(I had this on my 65 Polara w/a 383)with one of there blaster coils.Hooker used to make a super-comp style header(I had these in my 69 RR about 22 years ago),recently,I had a set of Schumacher tri-y's(in the Polara).Mopar has a purple-shaft cam that is supposed to be a 276 duration cam(I think with 480-490 lift).Rocker-wise,to correct your problem-I would side with whatever advise Superjay would have as I haven't changed rockers in the 2 383's that I had.
Old 08-18-2007, 09:15 AM   #8
jlhram's Avatar
thanks again for the replys, with everything goin on I haven't had time to get in the garage and now the truck is acting up think the fuel pump is goin out. thanks again guys I'll keep you informed on any progress
