Blend Door? - Page 2 - Hemi Truck Club
Like Tree11Likes
Old 05-15-2019, 08:38 AM   #11
Originally Posted by kcd1369 View Post
And you are sure its not the recirc door? That is the usual first one to go.
And the easiest one to replace. I had mine go bad on both the 03 and 05. All other doors on both trucks are and were fine.
Actually it is the recirc door I ordered. Dorman 325
Old 05-15-2019, 05:54 PM   #12
Recieved the door, so now I have no excuses to pull it apart and hopefully fix it.
SUPER BEE likes this.
Old 05-17-2019, 07:48 AM   #13
Gold-Member
kcd1369's Avatar
Are you planning to pull the dash apart for that door? Its really easy to change by just taking the front of the dash up to the radio surround panel, and the glove box out. A bit uncomfortable to do but pretty easy. On my 05 the door went right up through the fan hole. Then 2 screws on the motor and your there.
Old 05-17-2019, 08:01 AM   #14
I took it apart and carefully checked the doors. They all look like they are working. Still flow isn't right... So I'm thinking the evap core isn't flowing. Maybe dirty? Just don't know. I ordered the evap core and going to the shop to have the system evacuated and removed. Then on the bench should figure out what is restricting flow.
kcd1369 likes this.
Old 05-17-2019, 08:34 AM   #15
Gold-Member
kcd1369's Avatar
So you have a lack of air movement or just a lake of cold air movement?
Or both?
Old 05-17-2019, 03:53 PM   #16
No cold air, feels like the freon has leaked off. Air flow feels lacking but oddly better than when I started.
Old 05-17-2019, 07:12 PM   #17
xtremwlr's Avatar
Sneaking back in here, crawling out from under my rock (Tacoma).
My thread from when I replaced all the doors in my HVAC with the BlendDoor USA kit might help you.
https://www.hemitruckclub.com/forums...ork-28041.html
Redtruck-VA likes this.
Old 05-25-2019, 08:09 PM   #18
Tore it apart and checking doors again I missed that mode 2 door moves and is in place but the coupler has the limiter stop broken. Tried to find a replacement mode 2 door, but none were available. So I took the coupler from the blend door I bought and drove it into the mode 2 door, effectively repairing the door. Everything works and passed a diagnostic performance test. Got down to 40 degrees at the dash vent. I would call this fixed if it doesn't have a slow leak. Will know in a week.. or so...
charged392 and xtremwlr like this.
Old 05-26-2019, 03:51 PM   #19
Drove about 40 miles today and the ac worked like it should.. so at least it didn't leak down over night.....
xtremwlr likes this.
« 1st gen 12v | - »
