Wonít start codes p0562/p0700/p1684 - Hemi Truck Club
Old 03-11-2018, 12:23 PM   #1
2004 hemi ram stalled out on way home and havenít been able to restart it. Got new starter new alternator and new spark plug with no success. Battery at 12.7v but at cranking itís at 7v? Any one with this situation befor.
4301ram is offline   Reply With Quote
Old 03-11-2018, 01:24 PM   #2
Welcome to the forum. My guess is your battery ineeds to be replaced. Our Ram's are very particular about it's battery. When was it last replaced and are all the ground terminals clean? Battery...
Old 03-11-2018, 03:44 PM   #3
Want to say about early 2011 is when battery was replaced.
Old 03-11-2018, 03:47 PM   #4
Funny thing is check light is on but no codes show up up and also a little lightning bolt in gage cluster . We did recharge battery and use other battery before new alternator and starter were installed and no results.
Old 03-11-2018, 04:09 PM   #5
Does the engine crank? Can you hear the fuel pump pump when key is first turned on?
Old 03-11-2018, 06:09 PM   #6
TO THE HTC
Old 03-11-2018, 07:56 PM   #7
Yes it cranks but wonít start and i can hear fuel pump also. I aslo checked fuses and seem good. Cables for grounds are good and so are harness for power.
Old 03-11-2018, 07:58 PM   #8
Also when changing spark plugs thinking I might have flooded it due to too many cranking, they smelled like little fuel.
Old 03-11-2018, 08:03 PM   #9
Check the fuel pressure or at least see if fuel squirts out when schrader presses in. Also pull a coil up and see if your getting spark from a coil.
Old 03-11-2018, 08:10 PM   #10
Ok for sure pressure from fuel pump because fuel is spitting out of Schrader valve when the center needle is pressed. Havenít checked spark. Any advice on how to do spark check?
