6'' lift void power train warranty - Hemi Truck Club
Old 01-26-2016, 09:47 PM   #1
I have a ram 1500 something going on with the transfer case, when I put it in 4wd it makes a noise and the T case jumps, I had a load of fill drop of one day and the dump truck started spinning on the grass, he ask if I give him a pull with the pickup and I did, but the other day I heard the noise, so I have a appointment made to be my ram in but im wondering if they will fix it where I have a lift on it.
bedrock is offline   Reply With Quote
Old 01-27-2016, 01:58 AM   #2
boedacres's Avatar
did it have the lift when you bought it? It should be covered if it did. Also don't tell them you pulled a dump truck with it.
Old 01-27-2016, 05:00 AM   #3
No I put the lift on , but I bought it used I was going to tell them it was on it ,no I won't say anything about that for sure
Old 01-27-2016, 10:19 AM   #4
Lightbulb
Might have to approach more than one dealer to get results...
Old 01-27-2016, 11:14 AM   #5
that's what I was thinking to , I hope to get it covered, I was even thinking about taking the lift off but its lot of work. Can they tell if I said a dodge dealer put it on, the power train is up on feb 22 I hope I get it fix under warranty
Old 01-27-2016, 04:47 PM   #6
you can say you bought it that way but that's normally noted in the history pretty good. some dealers will do it some wont. deff don't mention that you pulled anything. if anything say you bought the truck and the first time you used 4wd for a simple trail drive it started making the noise.
Old 01-27-2016, 05:09 PM   #7
I brought the ram in 2013 , I just hope they cover it.
Old 01-27-2016, 05:51 PM   #8
HEMI COMMANDER's Avatar
Don't take it back to where you purchased it from because they will more then likely know it wasn't on it when your purchased it. Good luck with that.
GO DAWGS GO
RIP Commander RIP!
New Ride
Old 01-27-2016, 06:29 PM   #9
No its not the place I purchased it, I have appointment for Friday next week, if they say it's the lift ,I say a lift wouldn't cause that.
Old 01-27-2016, 06:36 PM   #10
It can cause a problem with the drive train if the geometry of the drive line is out of factory alignment tolerance. Does it engage into 4wd?
GO DAWGS GO
RIP Commander RIP!
New Ride
