Yoke ID - Hemi Truck Club
Old 09-10-2014, 11:41 PM   #1
Truck of the year 2014
Belgiquebasterd's Avatar
Yoke ID
Probably need a longer driveshaft for my T56 swap, can't find a local driveshaft shop that can do a aluminium driveshaft for me, there are however a couple of truck/agricultural shops around here that can weld me up a driveshaft, so will probably go that route. I'll use the stock aluminium transmission and differential yoke and source their steel driveshaft counterparts.
My question is how are the yoke type/sizes identified, are all dodge yoke's the same, is there a difference, did a bit of a google search and didn't come up with much? Checked the workshop manuals / exploded parts view but only dodge part numbers there for the full shafts are mentioned in there.
Thanks.
Old 09-11-2014, 09:02 AM   #2
I don't know about what fits the T-56. It is apparently used in a few different vehicles and I don't know if the output shaft remained the same across models. I did see reference to TH350 trans yoke fitting. If true that should make them much more available.
https://www.google.com/search?q=t-56...rans+slip+yoke
