Wooooooooo from rear end, goes away with foot off gas. - Hemi Truck Club
Old 12-04-2013, 08:08 PM   #1
Shifterbrains's Avatar
This happens or is most noticeable from 60-70 mph. Sounds real similar to a turbo sound. My Dakota made this exact same noise 4.7/3.92 with about 45k on it when I traded for this truck. This also has 3.92 gears (anti-spin) and 4x4.
Is it anything to worry about? My parking brake pads are gone, so it looks like I might have to pull the axles out a little anyway. If this noise is anything I can get rid of by adjustment or fluid change, I'll just do it all at once. Thanks!
Old 12-04-2013, 08:54 PM   #2
That's a sign of gear wear on the drive side of the set usually not anyway to get rid of the noise
The axles stay in when changing the parking shoes no need to pull out to change
Old 12-04-2013, 09:30 PM   #3
I couldn't see any way to change the shoes with the axles in place. The axle flange is so close, I can't even tell the basic shape of the shoes to order new ones! But the noise being normal wear is encouraging to hear. Thanks!
Old 12-05-2013, 06:14 PM   #4
Board of Directors-Bill
arocketman's Avatar
Not normal wear, just wear. If it get louder (and it will) you be wanting to get inside to see if it is gears or bearings.
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 01-29-2014, 04:21 PM   #5
Extreme Driveline Perf
Supershafts's Avatar
Sounds as though you are having a bearing going away, and it is likely its the main pin bearing, but it could be a carrier bearing also.
Old 04-14-2014, 07:28 PM   #6
Thanks, guys.
Old 04-14-2014, 10:58 PM   #7
If the parking brake is shot it could also be contributing to the noise.
Old 04-15-2014, 06:59 PM   #8
I don't know, my '01 Dakota with 3.92s had the exact same sound. I think it only does it under load. Take foot off the gas, it disappears, if memory serves. Usually doesn't.
