Woooooo from the rear @ 40 - 65 mphs - Hemi Truck Club
Old 01-04-2014, 06:51 AM   #1
Bama's Avatar
After 6 inches of snow & tons of ROAD SALT (225 miles worth) , My trk is humming pretty loud @ speeds of 40-65 mph, it is humming at all speeds. It does not sound like gears grinding just, humming (loud). Do I need to grease something ? (lol, that didn't sound right) ...
Old 01-04-2014, 12:48 PM   #2
The Original Bee
HemiSuperBee's Avatar
If its not the diff, probably axle bearings( will have to be replaced).
********AWARDS********
9 Best of Show
21 First Place
3 Class Awards
2 Truck of the Month
HTC Best Dressed Engine
Old 01-04-2014, 02:16 PM   #3
On a nice dry grippy road try swaying the truck side to side and see if noise comes and goes if so bearing up front is bad
If this is the case when turning to left loading right usually means right side bad if turning right loading left usually front left bad
Also try jacking truck up one wheel at a time and spin the wheel while holding the upper control arm if its not smooth you will know it
Old 01-04-2014, 04:24 PM   #4
Board of Directors-Bill
arocketman's Avatar
Just changed out my front hub bearings. If one is bad change them both.
05 QC
BLUE MAX
"Slightly Tweaked"
Just [email protected]
Old 01-05-2014, 06:36 AM   #5
Bama's Avatar
Thanks Guy's
Old 01-05-2014, 07:26 AM   #6
That's one of the other things that has to be done to my truck.
Ghost03hemi is online now   Reply With Quote
Old 01-12-2014, 07:47 AM   #7
Bama's Avatar
did the side to side, the whining sound stay's the same.. , gonna try to git it to the shop soon...
Old 01-12-2014, 07:51 AM   #8
One of 2 possibilities either both front hubs are bad (not usually likely) or the noise is from the diff pinion/carrier bearings
Old 01-18-2014, 09:21 AM   #9
Bama's Avatar
Thanx 392,... Is this costly?
Old 01-18-2014, 10:48 AM   #10
If its the diff bearings looking at around 600-800 repair with parts if that's the issue
