whining noise - Hemi Truck Club
Old 05-10-2011, 02:37 PM   #1
David
ATXHEMI's Avatar
I took my truck to the dealer because i was hearing a whining/ringing noise before upshifts. They basically rebuilt the tranny. Replaced the torque converter selenoid valve body clutches ect. Im not sure if the replaced them all. When i picked the truck up it was still makin noise. I took it back and it was then the ds front wheel hub. Trucks still makin noise around 2000rpms. Service advisor said its air noice around my cai. but its been on 3 yrs and never noticed it before. Any thoughts. Thanks in advance
Old 05-10-2011, 02:37 PM   #2
David
ATXHEMI's Avatar
Old 05-12-2011, 02:52 PM   #3
David
ATXHEMI's Avatar
well ive added the sonnex line pressure booster to see if it will help. guess i'll have to get another opinion from another shop.
Old 07-17-2011, 11:56 AM   #4
Did you ever get this figured out
Old 07-22-2011, 02:55 PM   #5
David
ATXHEMI's Avatar
Yea its coming from the intake. I can put the truck in drive and hold the break rev it up to around 2k rpm and it whines real high pitch. I emailed k&n and they said it air goin over the throttle blade. Just didnt understand why it didnt do it from the get go.
Old 07-29-2011, 07:19 AM   #6
schemigrunt's Avatar
I know there was a tsb on the liberty crd for a whinning noise and it dealt with the transmission(our trucks share the same trans as the liberty crd) . my truck started doing the same thing and I have thought maybe it was the cai but I started checking tsb and remember my liberty had the same issue and a tsb for that. so the best thing to do is get a different dealership to pull up the tsb for the liberty and have them use the updated parts (torque converter and front pump).
2005 regular cab ram 1500 slt. AEM cai, Magnaflow custom bent catback exhaust,custom made y pipe to replace the resticive factory one, tinited windows, 07 charger hemi badges, Hughes master transmission kit (waiting in my tool box to be installed) and hopefully more to come..
2000 Dodge Dakota 5.9 R/T club cab. intense blue metallic. stock block,Eagle forged crank, Eagle H beam rods, Keith Black Icon Forged pistions, Comp 512/510 lift cam, Mopar R/T 2.02 valve heads, Mopar 1.7 ratio rockers, Mopar/ Doug Thorley tri Y headers, Mopar single plane MPI intake manifold, T&B 55 mm Throttle Body, Vortech V1sc supercharger, Snow water methnol injection, Hughes Race clutchs and steels, TCI torque converter.
fixing up cars is like pringles once you fix one up you can never stop.
if you lift you lose... dont get in it if you cant stay in it.
schemigrunt is offline   Reply With Quote
Old 07-30-2011, 07:00 AM   #7
David
ATXHEMI's Avatar
The tranny was recently rebuilt at the dealership. They replaced the torque converter and some of the clutches and solenoid. Not sure why its still makin the noise.
Old 10-13-2011, 05:36 AM   #8
David
ATXHEMI's Avatar
So i put a Fastman TB and 3rd strike CAI and the noise went away. I wonder if when i cleaned the stock throttle body i messed something up.
