What brand trans filter - Hemi Truck Club
Old 02-04-2014, 08:19 AM   #1
rowdog_14's Avatar
I am going to drop my trans pan to install the Transgo kit. So while I have it apart I am going to change the fluid, filters and add the drain plug. I was looking to get a filter from any parts store near by, Autozone, Advance, Oreillys, Pepboys. Has there been any issues with a certain brand if not I will probably go to autozone since it is the closes and get their brand spin and pan filter. I did a search but did find and good information about filter other than most people choose NAPA or Dealer.
Current upgrades
- Jet 180 - Mopar Gauges- Class IV hitch - Borla Cat-Back - 4ga Dynamic Grounding - 10ga TB grounding - Sonnax trans line pressure - BBK Shorties#4009 - TheFastMan 85mm Throttle Body - SCT HemiFever Custom Tune - Magnaflow y-pipe #10748 - Doug's cutout #H1131 - K&N Intake 57-1533 - Comp 268 Cam -6.1 springs, pushrods- Summit UD Pulley
Upgrades to come and I am done:
1.Edge Torque Converter (2400-2600) 2. Race Ready Electric cutout 3. Detroit True Trac 4. Motive 4.10 gears 5. McGaughys shackles
rowdog_14 is offline   Reply With Quote
Old 02-04-2014, 09:50 AM   #2
I used NAPA last time I changed my filters. As for the drain plug, a O2s bung can be welded on the pan for a drain. And again a O2s plug for the drain plug, I got mine from Auto Zone.
Old 02-04-2014, 10:34 PM   #3
I only use dealers filters for trans since the screw on has known issues I use the dealer so there's none
Old 02-04-2014, 10:37 PM   #4
NewBlue's Avatar
I used a Wix filter set and the B&M plug. A welded on plug sounds good.
