Vibration when driving between 69 to around 78 MPH - Hemi Truck Club
Old 09-23-2015, 09:19 PM   #1
Gold-Member
kcd1369's Avatar
Well, I have this pretty bad shaking starting around 69 mph, and is there strong until I get over 80. But even then, its just diminished, not gone.
First, it seemed to be a tire out of balance, or a bent rim.
Got the tires road force balanced. Still there.
Then I found a set of new rims and tires. Had them balanced and put them on. But still it shakes.
Than I noticed while the rear wheels were off the ground, the drive shaft was bent. Must have happened when the pineon nut let loose. Had the shaft straightened and balanced. Still shakes.
While the dude was putting the shaft back in after balancing, we were talking about the vibration and he took a look at the front CV shafts and noticed the drivers side was very sloppy.
So, I finally had money to get a new shaft and wanted to change the hub bearing while at it, since it was the original still. Got them changed out today. Took it for a drive a little while ago and guess what, the shake is gone. There is still a faint vibration. But if I wasn't so sensitive to vibrations now, I might not have noticed. I will get the other side changed soon and I'm good to go.
So happy I finally found that freakin vibration source.
Old 09-23-2015, 09:41 PM   #2
Glad you found it David.
Old 09-24-2015, 02:33 AM   #3
Matt
MANual_puller's Avatar
Good deal I hate mystery shakes too! My stupid Mitsubishi has one that's intermittent. I notice it a couple times a week at any speed....
Old 09-24-2015, 04:27 AM   #4
Cool deal
Old 09-24-2015, 08:26 AM   #5
Excellent, a mystery shake can be very frustrating.
Old 09-24-2015, 08:53 PM   #6
FIXED
Old 09-25-2015, 07:06 AM   #7
Gold-Member
kcd1369's Avatar
I never even gave the front end much thought once I checked the staring and ball joints. Also, since I wasn't feeling it in the wheel. So I was everywhere else. I even knew those axles had some play, from when I had that rattling noise a while back.
Live and learn.
Old 09-25-2015, 07:15 AM   #8
Glad to here your figuring it out
Old 10-03-2015, 10:52 AM   #9
Gold-Member
kcd1369's Avatar
Well, more good news. Just took a 2 hour drive across the state, and my MPG are back up to where it was before. 124 Mi. @ 14.8 MPG
Now I'm going to do the bearing and shaft on the other side maybe it will go up even more.
Old 10-03-2015, 07:45 PM   #10
