Transmission problems - Hemi Truck Club
Old 06-20-2015, 06:36 PM   #1
So I have a 2006 Dodge Ram 1500 ,4wd, 5.7 Hemo.Truck has 148,000 miles on it. I have not done much pulling or towing with this truck. I bought it in 2008 with 21,000 miles on it.I had never changed transmission fluid or filters til last week when my wife was driving it and was real sluggish starting. I also had engine codes p0700 and p0750. I ended up changing out fluid,filters and shift solenoid. I thought I had problem fixed til i was driving it today.I was going down road about 65 mphand felt it slip and enging light cme on and then was sluggish for a bit, It seems to be working ok as of know but I know problem is not fixed, I would appreciate any helpful feed back, Thanks Jim
Ps I did not find any metal or material in pan when fluid was dropped
jrm3056 is offline   Reply With Quote
Old 06-20-2015, 07:13 PM   #2
James
DakotaJ's Avatar
First off, welcome to HTC.
Do you have access to a good scanner that'll show you the CVI numbers? Most tranny shop I know, frown upon changing the tranny fluid if it's never been done and it has that many miles. Have you done any WOT downshifts to pass any vehicles recently? There's several people on HTC that've had to rebuild their tranny multiple times. It's just the week link in these truck, if you like hot roddin. Our in house mechanics will be on shortly, and they'll be able to asset you.
Old 06-20-2015, 08:15 PM   #3
transmission
No I don't hot rod it. I am going to take it to a trusted transmission shop near me on monday
Old 06-21-2015, 08:33 AM   #4
Ok that code is for a low/reverse solenoid circuit. Of you changed the selnoid (was it the whole valve body) or just one little solenoid? Normally with that high of miles I would rec not doing the fluid normally issues arise waiting that long regardless of metal in pan. Have a good shop have a look but to me sounds like either a wire issue or valve body issue.
Old 06-21-2015, 08:54 AM   #5
Old 06-21-2015, 09:48 AM   #6
Gold-Member
kcd1369's Avatar
To HTC
And what they said as far as the tranny goes.
Old 06-21-2015, 02:23 PM   #7
jrm3056
