Trans stalling - Hemi Truck Club
Old 08-05-2017, 06:55 AM   #1
nsorenson's Avatar
Trans stalling
My 04 is starting to act up a bit. When I start it and put it in drive it takes a few seconds for it to get into gear. But if I wait a while go out and start it then put it in 1st it takes right off. Only thing I've done latley is clutch fan deletr which i wouldn't believe would have anything to do with this. The T1000 doesn't show any issues when I run diagnostics. Is there a senor I should ve looking to swap out?
Old 08-05-2017, 07:01 AM   #2
The trans filters are known for bleeding down on the 545rfe try doing a filter and gasket set from the dealer and let us know if it stops
Old 08-12-2017, 12:39 PM   #3
nsorenson's Avatar
Both filters? Amd what fluid do you recommend to put back in it?
Old 08-12-2017, 04:06 PM   #4
YES Both and atf4
Old 08-12-2017, 04:23 PM   #5
nsorenson's Avatar
That's what i thought but the guy in the parts department told me i only needed the one. I was sure he was wrong
Old 08-12-2017, 09:13 PM   #6
There is two.. flat filter and a spin on filter... I use valvaline atf..
smith92rc is offline   Reply With Quote
Old 08-13-2017, 08:43 AM   #7
nsorenson's Avatar
Yeah he gave me the flat one. I wasn't sure on the fluid said there was fluid there that said GM and Ford but ni Chrysler. Is that synthetic?
Old 08-13-2017, 08:55 AM   #8
xtremwlr's Avatar
Only use ATF+4, as charged392 said. Doesn't matter what brand, just use ATF+4.
The power steering also uses ATF+4...
Old 08-13-2017, 12:18 PM   #9
I never ask a parts store guy a question I dont already know the answer to. Lol..
Old 08-13-2017, 12:21 PM   #10
nsorenson's Avatar
Never done one before so I just went in and told him what I was doing so he just gave me the one. I should've researched it more before going in
