tranny service - Hemi Truck Club
Old 10-01-2014, 05:16 AM   #1
pri_i_oh's Avatar
tranny service
Now that I have the motor rebuilt on my Durango I want to do a tranny service. Especially considering the obvious lack of service. I've heard nightmares of people having problems after doing a service because of the pan gasket not seating correctly or something. Just wondering if anyone has any input or precautions. Obviously it takes ATF+4 but I was wondering if theres anything I can do to prevent any issues. I certainly don't need MORE issues...lol
Old 10-01-2014, 11:33 AM   #2
Pray with the miles sometimes issues arrise from messing with pan/filter internally. It's a simple process thou drop pan clean surface install parts reverse.
Old 10-01-2014, 11:35 AM   #3
pri_i_oh's Avatar
Ok so its like most trannys then.
Old 10-01-2014, 02:33 PM   #4
Cool
CAUTION: One thing to keep in mind, after you remove the flat filter, and pry out the filters old seal, be sure to install the new seal in the trans. FIRST, then install the new filter. DO NOT put the seal on the filter before installing it.
Old 10-01-2014, 05:31 PM   #5
pri_i_oh's Avatar
Ok cool. I just wanted to make sure there wasnt something spexial I was gonna run into or the need for some stupid special tool
Old 10-02-2014, 06:44 AM   #6
boedacres's Avatar
pan and filter does not change all the fluid you only change about 6 quarts I recommend getting a complete fluid flush. If done correct it back flushes the filter and all the fluid will be changed. DONT USE JIFFY LUBE/I had mine done at Dobbs if I remember it was 120.00 bucks. MY opinion.
