Tranny fluid and filter change- what's recommended? - Hemi Truck Club
Old 10-03-2011, 09:09 PM   #1
NewBlue's Avatar
I gotta get this done-
First change, is it worth the full fluid change or is the service change good enough?
Is it worth almost $5 a quart more for Amsoil ATF, considering any ATF+4 is synthetic?
What are the best filters to use?
Anyone add the B&M drain plug?
Thanks, guys.
Old 10-03-2011, 09:09 PM   #2
NewBlue's Avatar
Thanks, guys.
Old 10-05-2011, 08:43 PM   #3
rdsetgo's Avatar
I am going to use AMSOIL over the AFT+4 just for the fact that ATF+4 is like reg fluid instead of the syn that it should be!
CURRENTLY OWN 2012 Ram 2500 4X4 Crew Cab Laramie Cummins and 2013 Dodge Durango AWD Citadel HEMI!!
GONE 2010 Dodge Ram 2500 4x4 Big Horn Crew Cab HEMI, 2011 Dodge Durango AWD Crew HEMI, 2007 Dodge Ram 1500 Big Horn 4x4 Quad Cab HEMI, 2008 Dodge Durango SLT 4x4 HEMI, and my First 2004 Dodge Ram 1500 Quad Cab HEMI
2010 HTC NASCAR Champion
April 25, 2007!!
Old 10-06-2011, 03:32 PM   #4
I'm going to go with Royal Purple. I've already switched everything else in the truck over to RP, just have to get around to doing the trans now.
'05 Ram 1500 4x4 Quad Cab, yellow, Hemi/auto. 22" chrome SRT-10s with 305/45s, SC 3815, gutted cats, 1-chamber Flowmaster, 2" shackles.
CorDog is offline   Reply With Quote
Old 10-06-2011, 07:58 PM   #5
NewBlue's Avatar
I was told that all ATF+4 is synthetic.
I couldn't see doing just the service change and only doing half the fluid if I went to Amsoil, and I couldn't swing $200 for the fluid alone right now.
I opted for a case of NAPA fluid ($68), a WIX filter set, and B&M drain plug. Hope to get it done this weekend.
Anyone that's done this job, did you use the gasket, or just the RTV? The manual doesn't mention a gasket, just MOPAR RTV.
Old 10-07-2011, 10:32 AM   #6
I'm pobably going to do mine this weekend. I'm gonna use the gasket that came with my filter. Going to just change what's in the pan now and then again when I order a Mag Hytec pan later on.
Old 10-07-2011, 02:40 PM   #7
The Original Bee
HemiSuperBee's Avatar
Gaskets eventually leak, RTV all the way.
********AWARDS********
9 Best of Show
21 First Place
3 Class Awards
2 Truck of the Month
HTC Best Dressed Engine
Old 10-08-2011, 02:00 PM   #8
I changed my mind and went with rtv. No leaks as of yet anyway lol. Added 6 quarts of Royal Purple, might be a tad low so I'm gonna grab another quart when I go to town.
Old 10-10-2011, 08:49 PM   #9
NewBlue's Avatar
Yup, used new Permatex RTV for tranny fluid. There was no gasket there from the factory, so you must not need it!
Also picked up a tube of Permatex RTV for gear oil (next project).
