threw 6 tranny codes????help - Hemi Truck Club
Old 04-18-2007, 06:56 PM   #1
truck cut off on mme on the way to work this am,used my sc to read the codes.p0871,Tran fluid pres sens/switch c......po988, tran fluid pres sens/switch e.....po876,tran fluid pres sens/switch d....po846,tran fluid pres sens/switch b......po888, tcm power relay sense circ.....po700, trans ctrl sys error.Any body have this happen, whats up
rumble bee stings is offline   Reply With Quote
Old 04-18-2007, 07:23 PM   #2
It sounds to me like you blew that thing up. I would call Jerry or Denny at Sharadon Performance. http://www.sharadon.com/
They are the ONLY shop worth sending your transmission to for a rebuild.
Beast 2 is offline   Reply With Quote
Old 04-18-2007, 07:24 PM   #3
CentralTexHemi's Avatar
Man that many codes you need to get to Dodge and have that tranny checked out, I know you want answers but with that many codes and the fact the truck cut off your stuck taking it in or if its our of warranty to a transmission shop
Old 04-18-2007, 07:28 PM   #4
after it cut off initally I made it the rest of the way to work where it sat for the rest of the day.After work I cleared the codes and it got me home without any further codes or engine lights and ran normally??
Old 04-18-2007, 07:35 PM   #5
Man I would still be worried about what caused that and would still want it checked out
Old 04-18-2007, 07:44 PM   #6
Oh yeah,no doubt, gottaa get it checked out.I'm out of warrenty so I'll go to a mech.,should I reset the super chip to stock??
Old 04-18-2007, 07:57 PM   #7
Most mechanic shops (including mine) probably wouldn't be able to see if you had any issues. You should take it to a dealer so they can hit the truck with the DRB and see everything they need to see. A regular scanner will not get the job done.
I know it sucks but this is one time where the dealer is the best option.
I wouldn't have the dealer rebuild/replace the transmission if needed, I would send the transmission to Sharadon, and ONLY Sharadon.
Old 04-18-2007, 07:58 PM   #8
I agree, dont feel bad my baby is with them right now
Old 04-18-2007, 08:00 PM   #9
A complete diagnostic check by the dealer will run anywhere from $60 - $90. Return the truck to stock (remove the S/C programming) and take her in... just to be safe. Not sure why so many DTCs popped - can't say it's a fluke with that many codes.
Old 04-18-2007, 08:40 PM   #10
will go to dealer tomorrow after deprograming the sc.If it ends up being a major problem I will have to find someone local to fix it as I am single and live alone.It is my only vehicle and can't get to work etc, so packing up the tranny and sending it off is not much of an option for me.
