Symptoms of excessive hub bearing play? - Hemi Truck Club
Old 03-22-2008, 10:39 PM   #1
ckyrux's Avatar
What are the symptoms of hub bearing play? I have 2003 Ram Hemi 4x4.
ckyrux is offline   Reply With Quote
Old 03-31-2008, 02:22 PM   #2
I had a squeel sound coming from the right front. It sounded like a warning tab on the brakes rubbing the rotor. I purchased some new pads to put on and when I jacked up my truck I saw the wheel / tire move in quite a bit. I grabbed the top and bottom of the tire and I could move it about a quarter inch each way, cheked driver side and almost as much movement. I replaced both hub assemblies and there is absolutley no movement. I have 80K miles on my 4 X 2.
Rcimp is offline   Reply With Quote
Old 04-03-2008, 12:10 PM   #3
brand_x_racing's Avatar
minor vibrations, when turning at about 30mph turn the wheel back and forth and if you feel the front kinda pop or bump something that dosent feel right might suspect it, and...... jack the truck up and grab the tire try to move it all ways, if you feel it move, then you know!
Old 04-05-2008, 12:11 PM   #4
ckyrux's Avatar
Thanks fellas. I jacked it up and sure as ****, there is alot of movement. Took it in and got it replaced and drives like new now. Thanks alot.
