Sonnax Question - Hemi Truck Club
Old 01-14-2015, 10:19 AM   #1
Enormous Member
Hugh Jassole's Avatar
Sonnax Question
I just had my trans rebuilt. I had a trans-go shift kit installed. I also have a sonnax line pressure booster installed. Any issue with having them both ?
My other truck is an R/T
Old 01-14-2015, 10:26 AM   #2
Nope
Old 01-14-2015, 10:46 AM   #3
Red Trucker
HemiLonestar's Avatar
No issue, but if you're upping the line pressure with a tuner (you have the trans tuning capability) then you might want to take it out.
HemiLonestar is online now   Reply With Quote
Old 01-14-2015, 02:54 PM   #4
Enormous Member
I can't trans tune mine, it's too early of an 05. It's essentially an 04
Old 01-14-2015, 04:41 PM   #5
Have you tried to tune trans or you getting a code saying it can't like me
Old 01-14-2015, 06:25 PM   #6
jmgak47's Avatar
Superchips/Diablo stack...
2014 RAM 1500 Express QC 2wd Hemi
5.7 Stock Block
1/4 - 12.18 @ 110.15 NA
1/8 - 7.74 @ 89.06 NA
426 Stroker
1/8 - 7.16 @ 95.79 NA
jmgak47 is offline   Reply With Quote
Old 01-16-2015, 09:56 AM   #7
Enormous Member
As a matter of fact Jay (Hi Jay) looked at it for me, and yeah. My PCM is too early. I'd need to stack Diablo & Superchips. I think I'll just send the TCM to B&G instead.
Old 01-16-2015, 10:34 AM   #8
Truck of the year 2014
Belgiquebasterd's Avatar
Keep in mind if you ever had a predator installed on your truck you can't install a superchips, even if you return the predator back to stock. You need to have it dealer reflashed or something.
Ask me how I know :-(, 150$ down the drain. Arrington can raise the rpm limit and raise the idle rpm on 2003 pcm's.
Old 01-16-2015, 11:45 AM   #9
Enormous Member
no, I'm using an i-1000
