Sonnax line pressure booster worth it? Pro's Con's? - Hemi Truck Club
Old 09-17-2016, 09:43 AM   #1
Hi, I have a 04 Ram 4X4 Hemi, What do you guy's know about these?
Are they worth it?
Do they hurt the life of the tranny or do they help it?
Does it change the way it shifts?
Do I need to use the spring? I'd rather wait to add that part when I do the next fluid change if I need it.
Thanks
Line Pressure Booster Kit - RFE-LB1 - Sonnax
Old 09-17-2016, 11:14 AM   #2
Only helps! Spring can be done during a pan service later on
Old 09-17-2016, 11:44 AM   #3
IMO anytime you can do something to make a trans shift tighter and hold the clutches with more pressure is a good thing.
Old 09-17-2016, 12:27 PM   #4
Imo, no
Old 09-17-2016, 12:38 PM   #5
I've used one with no detectable ill effects for 9 years and definitely firmer more positive shifts. A cheap, quick mod IMO .
Old 09-17-2016, 12:50 PM   #6
This is also the new design where as the old one had some quirks and sometimes ruined trans. This design won't hurt the Trans cheap good mod
Old 09-17-2016, 01:37 PM   #7
What does the spring change?
Old 09-17-2016, 02:39 PM   #8
Not that it changes anything but I believe it's a common broken spring on rebuilds.
Old 09-19-2016, 06:23 AM   #9
I have heard that it should not be used with a Tuner, any of you guys running it with one?
Old 09-19-2016, 09:08 AM   #10
Speaking only from my own experience I've been using the Sonnax with the old 3815 SuperChips set to the performance tune for over nine years now with nothing but excellent results .
