Solenoid Pack? - Hemi Truck Club
Old 03-11-2017, 11:47 PM   #1
crash83's Avatar
Solenoid Pack?
So just replaced the fuel pump and bought new tire for my ram and on the way home my check engine light came on.
My truck has been down since August with a failed fuel pump.
The last time my truck sat for more than a month i had the same code pop up ...but it would go away after a few days.
I know that the filters have to come out and the valve body dropped to get to the solenoid pack.
And i believe i'm more than capable to do it.
However if the shift pack was bad wouldn't i have transmission issues? Not shift correctly or ?????
The transmission works great with no issues at all.
So any one of you guys done this before? What should i expect?
crash83 is offline   Reply With Quote
Old 03-12-2017, 05:40 AM   #2
What code are you getting?
The job itself is very easy to do just messy. Put in neutral,drop pan,unplug big clip,remove 8mm headed bolts only then lightly pry down avoiding the rain to come!
Old 03-12-2017, 06:22 AM   #3
What year Ram do you have?
Old 03-12-2017, 06:30 AM   #4
There is an update solenoid pack for the 545/68rfe trans. You must use the white plug solenoid. It's an update that super-seeds all of the other solenoid packs.
http://www.ebay.com/itm/Transmission...9XWMba&vxp=mtr
Old 03-12-2017, 08:15 AM   #5
What's that piece between the solenoid pack an gasket?
Old 03-12-2017, 11:45 AM   #6
Cam plate for the updated solenoid pack. The stage 3 needs one too.
Old 03-12-2017, 01:51 PM   #7
crash83's Avatar
Sorry it's a 2004
So go with the update pack?
What's the difference?
Old 03-14-2017, 01:14 PM   #8
crash83's Avatar
Is the solenoid pack something that can be purchased elsewhere?
Can I pick it up at Napa / Autozone/ Advanced?
Also as I asked above what exactly is the "upgrade" in the upgraded or updated pack?
I tried google but couldn't find anything concrete...
Old 03-14-2017, 03:48 PM   #9
Smokin' Joe's Avatar
I'd go with Mopar brand. Everything I've done to my Dodges with the auto parts stores, varied in design a bit. Mopar bolted right up and was easy! Try eBay if you want it for a little cheaper than going to the dealer.
I'm in Spring also. Off Rayford and 45N. Where about are you??
2003 SLT 2WD QC, Debaged, Drilled & Slotted Rotters w/ Ceramic Pads, 2" Drop Shackles
SJ
Old 03-14-2017, 05:42 PM   #10
crash83's Avatar
Off of Rayford and 45....
kidding...i'm off of Riley Fuzzel or 99
