Shifting problems when towing - Hemi Truck Club
Old 04-20-2015, 08:17 AM   #1
I recently purchased a 2004 Ram 1500 5.7 CC with 3.93 rear end. It has only 88,000 miles on it. I tow about a 6500 lb travel trailer. The truck shifts fine when not towing, but is a real problem with the trailer. First problem: when accelerating to enter an expressway, it shifts from 1st to 2nd fine, then stays in 2nd seemingly to long (to about 40 MPH) then downshifts quickly thru 3rd then directly into overdrive. The engines lugs down to about 1700 or 1800 RPM and ruins the additional torque needed to get up to highway speeds. More or less accelerator pressure doesn't keep it in 3rd. Second problem: The engine turns so slow at 60 to 65 MPH towing (about 1800 RPM) that the truck can't maintain speed and constantly falls off cruise and then downshifts. The manual indicates overdrive is supposed to work in both tow and non-tow modes, but I wish there was a way to defeat it when towing. Is this normal for this truck or is there a tranny problem? If so, any thoughts on the possibile points for repair?
RayL is offline   Reply With Quote
Old 04-20-2015, 08:20 AM   #2
RayL
Someone should be along soon to help you sort out your question .
Welcome to HTC
Old 04-20-2015, 09:20 AM   #3
You should have a OD button on the end of your shift lever. Turn it off and see how it does.
Old 04-20-2015, 10:40 AM   #4
Thank you for the reply.
It does have the tow mode button on the shift column, but it doesn't resolve the problem. There is about 300 RPM difference between tow mode (1800 RPM) and non-tow (1500 RPM) settings at about 65 MPH. Still way to little torque for maintaining speed under a tow load or accelerating.
Old 04-20-2015, 11:12 AM   #5
Jim-CO Chapter Dictator
RockyMtnXpress's Avatar
Have you owned the truck since new?
I am thinking about this comment, "quickly thru 3rd then directly into overdrive" might have the transmission programed into something other than towing or stock. It's a possibility. Not saying it is. I know mine, at 70, will hang in third running 3 grand, with 3:93 gears and with a slight pressure on the pedal. Only when conditions are right (no slope, no headwind, etc.) and backing off the pedal a few hundred will allow the shift to occur. "Tow Haul" is meant to hold each of the primary gears longer to maintain transmission temperature and not allow it to, in a word, use 3rd gear as a stepping stone. More-so when pressure is applied to the gas pedal. When the right conditions occur, it will shift into OD.
Another possible is condition of the transmission. Fluid and filter and when was it last changed?
One thing for sure when towing and the way the transmission is responding, is make sure the tank is filled with 91 octane. For sure you don't need anything less when pulling a load. Just making sure one thing doesn't lead to another.
Old 04-20-2015, 11:21 AM   #6
Thanks for your insight. I have been using 89 octane. It seems to give a little better mileage than 87. You mentioned the "transmission programming". Can that be reprogrammed? If so how? As I'm not the original owner, I'm not sure if/when the fluids/filter have been changed.
Old 04-20-2015, 12:18 PM   #7
It can be reprogrammed and (or) verified via dealer service. Ask to see if any DTC has occurred or a possibility reprogramming was done. Tell them you suspect there are problems when you're towing. As I said, "You never can tell" and this will give you a good idea "IF" something was done. I know my docs for my SuperChips Tuner will warn me to never tow haul long distances (or to never at all) with different tunes other than towing. Each tune will change a boatload of things...Including shift points.
THEN
If I was you, I would go through with a transmission service, change rear differential oil, transfer case fluid (if you have one) and front end differential oil (if you have one). Don't mean to be spending someone else's money, but it is way better to know than not. Especially, during the summer heat that will be upon us in another month. Add to that towing...Hmmm?
FYI on octane: My owners manual tells me to use a premium fuel when pulling a heavy load or driving a fully-loaded vehicle when humidity is low and the temperature is high. They also tell us a light spark knock at low engine speeds is not harmful to the 5.7 HEMI. I am not one to worry and resolve such as to exceed their recommendations...just a little. Friendly advice from the stranger from the greater SW where it becomes a hit or miss on gas quality and blends.
Old 04-20-2015, 12:26 PM   #8
What size tires are you running?
Old 04-20-2015, 12:41 PM   #9
Tire size
It has the factory option 20" tires. Running on recent Goodyear Wranglers P275 60 R20, at the recommended 35 lbs. Trailer tongue weight is about 800 lbs with an Anderson WD, anti-sway hitch. Trailer tires are new Trailer King ST205 75 R15 at 45 lbs.
Old 04-20-2015, 12:46 PM   #10
Those should be 33" tall and not a problem for the 3:92 gear. How sure are you that you have a 3:92?
