Rear Axle Question - Hemi Truck Club
Old 07-21-2015, 08:00 PM   #1
LowerThatRam's Avatar
Rear Axle Question
How do I figure out if I have the 9.25 or the 9.25ZF axle?
The gears on Moe's Performance say they will not fit the 2011&up with 9.25ZF axle...
I have a 2011 2WD HEMI, what axle do I have?
LowerThatRam is offline   Reply With Quote
Old 07-22-2015, 08:30 AM   #2
A zf
Old 07-22-2015, 10:23 AM   #3
Thanks,
I found this PDF online.
http://eastcoastgearsupply.com/files...25-zf-tech.pdf
to tell the difference via the diff cover.
Old 07-22-2015, 10:32 AM   #4
Gold-Member
kcd1369's Avatar
Old 07-22-2015, 04:47 PM   #5
NICE FIND - Great info...
Old 07-22-2015, 11:07 PM   #6
FASTHEMIRAM05's Avatar
Some good info and some bad in that article...
It is possible to do a carrier swap on the ZF to a DTT....
Had 2002 4.7 RCSB 14.2
Had 2011 RCSB 12.41
Had 2012 RCSB 13.99
Had 2016 QCSB 13.0
2011 Drag Truck....
Old 07-29-2015, 08:23 PM   #7
Extreme Driveline Perf
Supershafts's Avatar
Why is this being misinformed... the 9.25 is NOT a ZF.... only the front diff is ZF.
The 3rd design of the 9.25 which took place between 2003, 2007 and then 2011 is still a 9.25... All they did for the latest was change carrier height or ring location and bolt circle and axle lengths...
THAT IS ALL THAT CHANGED.
. It is not a ZF
Old 07-29-2015, 08:26 PM   #8
Some people...companies should REALLY pay attention.... unbelievable.
Also so you all know... ZF are all IS (Independent Suspension).
They are so complicated the place that made that pdf wouldn't have a CLUE...
Most are friction welded or laser welded gear to carrier...
Again the 9.25 IS NOT A ZF Differential !!!!
Old 07-29-2015, 08:39 PM   #9
Appreciate the clarification Supershafts on the newer trucks .
Old 07-29-2015, 08:41 PM   #10
Anyone needing help re-gearing the latest re-design let me know it is not a problem... someone tag those idiots from whatever gear company that is to this thread for some schooling....
