Pinion/driveline angle - Hemi Truck Club
Old 03-01-2015, 12:16 PM   #1
Truck of the year 2014
Belgiquebasterd's Avatar
What angle do you guys have your driveline?
On mine:
Pinion is 5,6 down from the driveshaft
Trans is 3,2 up from the driveshaft
Any opinions, suggestions?
Old 03-01-2015, 12:25 PM   #2
That's about right with accel almost perfectly
Inline I would say
Old 03-01-2015, 05:44 PM   #3
I'll be rechecking mine again during the upcoming trans install. But what I strive for is both transmission center line and pinion center line to be parallel to one another while under load (acceleration).
